[Solved] UMS Uses all buffer while scanning folder then crashes
ultrasuperman
Post by ultrasuperman »
I have v7.0.0 and the first time I boot up UMS I notice the memory usage slowly go up while it scanning folders (takes about 7 minutes) until it hits 742mb then UMS freezes and I need to open task manager and close Java. I have everything defaulted and it works fine on the second boot, it's just something in the first boot.
Re: UMS Uses all buffer while scanning folder then crashes
This is something we are working on, where the memory doesn't get freed as it should. It has been a bug since v5 but now everyone is seeing it because of the initial scanning added in v7
This should be fixed in 7.0.1
