[Solved] Playback 4K in LG TV
abominalizer
Post by abominalizer »
I kinda new to this but I have a 4K tv, a LG 77UH, I can use UMS for every 1080P file, but I cannot play 4k.
If I plug the HDD to the TV the 4K file plays np.
(675.13 KiB) Downloaded 1105 times
valib
Re: Playback 4K in LG TV
Post by valib »
You can try to add to your LG-WebOS.conf the
MaxVideoWidth = 3840
MaxVideoHeight = 2160
abominalizer
where? after all the code?~
Added at the end, same thing, TV says Unable to reproduce File, Format not recognized
valib
Post by valib »
Please can you reproduce the bug (trying to play the 4K video) and provide the log? I would like to see the communication between UMS and TV.
abominalizer
There
(404.59 KiB) Downloaded 1172 times
valib
Post by valib »
The problem is that your 4K video has DTS-HD audio which is not supported by the TV (is not set in the .conf) and the video is transcoded. There is also other other problem because there are two video streams in the media file and both are transcoded into one output stream with the FFmpeg parameter
-map 0:v
which in fact should be
-map 0:v:0
. This is a bug in the UMS.
Can you try to use the .conf I provided and after test send the log?
LG-WebOS.conf
(2.48 KiB) Downloaded 1111 times
abominalizer
Same deal.
(600.64 KiB) Downloaded 964 times
valib
Post by valib »
I have new .conf for you.
LG-WebOS.conf
(2.51 KiB) Downloaded 1377 times
abominalizer
Sorry to bother you with this =(.
Same deal but this time the TV was "loading" for a bit longer before showing the error.
(643.45 KiB) Downloaded 1034 times
valib
Post by valib »
OK. Now the TV is asking for the video without transcoding. If the TV still shows error could mean that this media format is not supported via DLNA but is supported from HDD which is common problem. There could be also problem somewhere else. Seems to me that even if the video file extension is
.mp4
in fact it is an
.mkv
format. Can you provide the MediaInfo output for that file? Do you have any other 4K video you can test?
