Check Network Connection - Samsung TV
I am getting check Network Connection Error on my Samsung TV at random internals. The only pattern is 4k files get this error more often.
Attached are the logs.
- (415 Bytes) Downloaded 331 times
Re: Check Network Connection - Samsung TV
There is no information in the attached zip file. Have you made sure that there really isn't a problem with your network connection? If you're using WiFi your bandwidth might be to small, or if your CPU is weak and you're transcoding it might not be able to keep up.
