Phillips 65PUS7502/12
mitsucats
Post by mitsucats »
Hallo,
I have a question for UMS, i have a new Phillips Televison 65PUS7502/12 and i would like to use
UMS to share my videos and picture and so on from my pc, and it has always worked on my old Samsung TV.
The problem is that i start UMS chose what folder i would like to share and then i restart the server, and go to
my Television and go to "Quelle" and chose "Universal Media Player"
Then i see the diffrent folder and i chose a video and then it loads a little and then i says could not be reead / video was not found" something like
this because my Television is in German language.
i have talk with Phillips and they says it is DLNA competible with 1.5 oder so.
i am using windows 10
The logs dont help so much because says only this video startet and video stopped
i have not change anything and use the Phillips-PFL.conf
Re: Phillips 65PUS7502/12
If you make trace logs like described, they will help a great deal. We're not only looking for the error, but for what happens before the error. The problem is probably that there is no working renderer configuration for your new TV in UMS. New models must often have a profile created before they will work. I'm 99.9% sure the problem isn't with the TV.
mitsucats
Post by mitsucats »
Hallo.
I have now try to make a Debug, i hope this maybe help a little.
now i dont see what i have share on my pc on my televission, but on the television i see the UMS but nothing inside.
on the logs says this today. and i have also testet with a laptop but same result.
now i can see everything on my television, i have found out that all my music videos from youtube and so on. now works, but movies i have on my pc dont work just say that could not be read or movies not found.
The movies just starts and stopping
08:08:37 INFO Started playing 10 THINGS I HATE ABOUT YOU 1999.MKV on your TPM171E-a1487fc30a0495f0b5eacf9c406fce32
08:08:42 INFO Stopped playing 10 THINGS I HATE ABOUT YOU 1999.MKV on your TPM171E-a1487fc30a0495f0b5eacf9c406fce32
08:08:44 INFO Started playing 50 FIRST DATES.mkv on your TPM171E-a1487fc30a0495f0b5eacf9c406fce32
08:08:53 INFO Stopped playing 50 FIRST DATES.mkv on your TPM171E-a1487fc30a0495f0b5eacf9c406fce32
P.S Now i have tried to go to 50 FIRST DATES and then i go to the transcode folder and chose no transcoding. then i can see it but 10 THINGS I HATE ABOUT YOU 1999 i do the same but then it start and 4 seconds later is just stopped.
ums_dbg2.zip
(969.05 KiB) Downloaded 372 times
mitsucats
Post by mitsucats »
Hallo
now i have playing alot, and after i have search the whole internet, i am comming up with this profile. but a little problem, the profile works okay, some movies you can see with VLC and other you need to go to Transcoding and chose no transcooding. also if you would like to see them in HDR.
But if i add this to the profile
MaxVideoWidth = 3840
MaxVideoHeight = 2160
Then i starts with HDR but then the movies alwas loading every 10-20 seconds. if i juts remove
all the movies works fine and also if i go to no transcoding then it starts also in HDR.
That is the normal profile for Samsung 9 Series. with a little touch. but it is not perfect
maybe someone here cann help finish it
# Profile for Samsung 9 Series TVs.
# Support MPO images as well (image/mpo)
# issue: posting.php?mode=reply&f=9&t=9249
RendererName = Samsung 9 Series
# User-Agent: DLNADOC/1.50 SEC_HHP_[TV] Samsung 9 Series (65)/1.0 UPnP/1.0
# friendlyName=[TV] Samsung 9 Series (65)
# uuid:aa54de66-0ecd-4936-bd2f-c7b4c381f4f5
# manufacturer=Samsung Electronics
# modelName=UE65KS9590
# modelNumber=AllShare1.0
# modelDescription=Samsung TV DMR
# manufacturerURL=http://www.samsung.com/sec
# modelURL=http://www.samsung.com/sec
# http://www.samsung.com/us/support/answer/ANS00049952/
# http://www.samsung.com/us/support/answer/ANS00045927/
# http://www.samsung.com/us/support/answer/ANS00049184/
UserAgentSearch = Samsung 9 Series
UpnpDetailsSearch = Samsung 9 Series
LoadingPriority = 1
TranscodeAudio = WAV
SupportedVideoBitDepths = 8,10
H264Level41Limited = true
SeekByTime = true
DefaultVBVBufSize = false
ChunkedTransfer = true
TranscodedVideoFileSize = 1000000
SubtitleHttpHeader = CaptionInfo.sec
PrependTrackNumbers = true
CharMap = / :
MediaInfo = true
# Supported video formats:
Supported = f:3gp|3g2 v:h264|mp4 a:aac-lc|he-aac m:video/3gpp
Supported = f:avi v:divx|h263|h264|mjpeg|mp4|mpeg1|mpeg2|vc1|vp6|wmv a:aac-lc|he-aac|ac3|eac3|lpcm|mp3|mpa|wma m:video/avi gmc:0|1
Supported = f:divx v:divx|h263|h264|mjpeg|mp4|mpeg1|mpeg2|vc1|vp6|wmv a:aac-lc|he-aac|ac3|eac3|lpcm|mp3|mpa|wma m:video/x-divx
Supported = f:flv v:h263|h264|mp4|vp6 a:aac-lc|he-aac|mp3 m:video/x-flv
Supported = f:mkv v:h264|h265|mp4|mpeg1|mpeg2|vc1|vp6|wmv a:aac-lc|he-aac|ac3|dts|dtshd|eac3|lpcm|mp3|mpa|wma m:video/x-mkv
Supported = f:mkv v:h263|h264|h265|mp4|mpeg1|mpeg2|vc1|vp6|wmv a:vorbis m:video/x-mkv n:2
Supported = f:mov v:h263|h264|mjpeg|mp4|mpeg1|mpeg2|vc1|vp6|wmv a:aac-lc|he-aac|ac3|eac3|lpcm|mp3|mpa|wma m:video/quicktime
Supported = f:mp4 v:h264|h265 a:aac-lc|he-aac|ac3|dts|dtshd|eac3|lpcm|mp3|mpa|wma m:video/mpeg
Supported = f:mpegps v:mpeg1|mpeg2 a:aac-lc|he-aac|ac3|lpcm|mp3|mpa m:video/mpeg
Supported = f:mpegts v:h264|h265|mp4|mpeg2 a:aac-lc|he-aac|ac3|dts|dtshd|eac3|lpcm|mp3|mpa|wma m:video/vnd.dlna.mpeg-tts
Supported = f:rm a:cook m:video/vnd.rn-realvideo
Supported = f:webm v:vp8|vp9 a:vorbis m:video/webm n:2
Supported = f:wmv|asf v:mp4|vc1|vp6|wmv a:wma m:video/x-ms-wmv
# Supported audio formats:
Supported = f:aiff m:audio/L16
Supported = f:ape m:audio/ape
Supported = f:flac m:audio/x-flac n:2
Supported = f:m4a|alac m:audio/mp4
Supported = f:mp3 m:audio/mpeg
Supported = f:oga m:audio/ogg
Supported = f:vorbis m:audio/vorbis n:2
Supported = f:wma m:audio/x-ms-wma
Supported = f:wav m:audio/wav
Supported = f:aac m:audio/x-m4a
Supported = f:mpa|mp3 n:2 s:48000 b:327680 m:audio/mpeg
Supported = f:wma n:2 a:wma s:48000 b:348160 m:audio/x-ms-wma
Supported = f:mp4 n:6 a:aac s:48000 b:327680 m:audio/mp4
Supported = f:aiff|wav n:1 a:lpcm s:44100 b:1445069 m:audio/L16;rate=44100;channels=1
Supported = f:aiff|wav n:2 a:lpcm s:44100 b:1445069 m:audio/L16;rate=44100;channels=2
Supported = f:aiff|wav n:1 a:lpcm s:48000 b:1445069 m:audio/L16;rate=48000;channels=1
Supported = f:aiff|wav n:2 a:lpcm s:48000 b:1445069 m:audio/L16;rate=48000;channels=2
Supported = f:adts n:2 a:aac-lc s:48000 m:audio/vnd.dlna.adts
Supported = f:mp3|mpa n:2 s:48000 b:327680 m:audio/mpeg
Supported = f:mp4 n:6 a:aac-lc s:48000 b:327680 m:audio/mp4
SupportedExternalSubtitlesFormats = MICRODVD,SAMI,SUBRIP,TEXT
SupportedInternalSubtitlesFormats = ASS,DIVX,SUBRIP,VOBSUB
mitsucats
Post by mitsucats »
Hallo
Those people that have this type of television, i have now found out how to use universal media player and can now look movies with HDR and 4k wihtout any problem.
I'm sorry that nobody else responds. I don't have time to deal with renderer configurations now, so I was hoping some of the others would do it. If it works for you, that's great though, but I find it strange if you have to use VLC instead of FFmpeg - which normally works much better.
