[Solved] *.mp4 streaming on PlayStation3 (PS3) not working
Hey folks,
I've got a similiar problem as the colleague here viewtopic.php?t=1953 and no solution.
UMS streaming works like a charm, except for PS3 i've got an issue with *.mp4 files - it says "corrupt or defect data"
Streaming same file to android tablets (accessing UMS via VLC android client) is working fine.
I found this here in the log:
Thx,
t-eddie
DEBUG 2018-07-06 11:23:12.586 [StartPlaying Event] net.pms.dlna.DLNAResource The full filename of which is: G:\Moviez\Kinder\Hotel Transylvanien BDRip DL German AC3 x264-Oxy.mp4 and the address of the renderer is: 192.168.1.16
TRACE 2018-07-06 11:23:12.586 [HTTPv2 Request Worker 2] net.pms.network.RequestV2 Transfer response sent to PlayStation 3:
HEADER:
HTTP/1.1 206 Partial Content (non-chunked)
TransferMode.DLNA.ORG: Streaming
Content-Type: video/mp4
Content-Range: bytes 0-1917016010/1917016011
Accept-Ranges: bytes
Connection: keep-alive
Server: Windows_7-x86-6.1, UPnP/1.0 DLNADOC/1.50, UMS/7.1.0
Content-Length: 1917016011
TRACE 2018-07-06 11:23:12.945 [UPNPHelper] net.pms.network.UPNPHelper Received a M-SEARCH from [192.168.1.1:36639]: M-SEARCH * HTTP/1.1
HOST: 239.255.255.250:1900
MAN: "ssdp:discover"
MX: 5
ST: urn:schemas-upnp-org:device:avm-aha:1
DEBUG 2018-07-06 11:23:13.241 [HTTPv2 Request Worker 2] net.pms.network.RequestHandlerV2 Connection error: java.io.IOException: Eine bestehende Verbindung wurde softwaregesteuert
durch den Hostcomputer abgebrochen
DEBUG 2018-07-06 11:23:13.241 [HTTPv2 Request Worker 2] net.pms.network.RequestHandlerV2 Premature end, stopping...
TRACE 2018-07-06 11:23:13.288 [HTTPv2 Request Worker 3] net.pms.configuration.RendererConfiguration Matched media renderer "PlayStation 3" based on address
Fore sure i had UMS running in trace mode and attached the log files - hoping that someone is able to help me out here.DEBUG 2018-07-06 11:23:13.241 [HTTPv2 Request Worker 2] net.pms.network.RequestHandlerV2 Connection error: java.io.IOException: Eine bestehende Verbindung wurde softwaregesteuert durch den Hostcomputer abgebrochen
Thx,
t-eddie
- (370.09 KiB) Downloaded 342 times
Re: *.mp4 streaming on PlayStation3 (PS3) not working
So, I didn't made it work with orignal set-up...unfortunately.
I used free tool Handbrake (https://handbrake.fr/) and converted it file into *.mkv with 1:1 set-up, but it didn't work either.
So i did it again, with pre-setting for PlayStation and removed in addtion all subtitles....and now it's working like a charm
