itunes not found
itunes not found
I just started with UMS, using Windows 7.
I want to stream my itunes-DB. The Problem is, i am using different itunes-DBs. Now UMS automatically uses the standard DB (c:\users\[username]\music\iTunes) which is an empty DB on my PC. Is there any possibility to change the iTunes-Folder used by UMS?
Re: itunes not found
You could always use the "Add Directory" button and navigate out to your non-standard installed iTunes Directory location.
Universal Media Server Wiki!
i want to use the database from itunes, the playlists
