Version 7.3.1 released
General:
This release fixes a lot of bugs we found based on user feedback, and updates translations.
Changes since 7.3.0:
  • General:
    • Fixed transcoding of videos with multiple audio streams with FFmpeg
    • Fixed not being able to delete folders containing folders that are within watched folders on Windows
    • Fixed Fully Played status not saving for some users
    • Fixed files not being immediately deleted from the database if their parent folder was deleted
    • Fixed standalone build auto updater downloading non-standalone builds
  • Languages:
    • Updated translations via Crowdin:
      • Chinese Simplified translation completed
      • French translation completed and validated
      • Italian translation updated
      • German translation completed
      • Polish translation completed and validated
      • Portuguese translation completed
      • Portuguese (Brazilian) translation updated
      • Romanian translation completed
      • Russian translation completed
      • Spanish translation completed
Compatibility notes:
erick diangilis
Re: Version 7.3.1 released
Post by erick diangilis »
hi subjunk thanks for the release i've tested out this new version on the ps4 media player with the ps4 pro it's working pretty good i had no issues to update the contents inside folders and they're also syncronized very fast wich is very nice. i also tested all the content from photos to vídeos including mkv with and without imbued subtitles they're working fine. sound quality is also ok the playback quality is also nice too with no stuter or judder. the translation to brazilian portuguese is ok too thanks for the update on it.
keep up with the good work have a good weekend. :D
Thanks for the feedback erick!
jaapie18
Post by jaapie18 »
Can you play movies with dts on ps4?
That should be working
JDN165
Post by JDN165 »
Installed 7.3.1 and all seems to work perfectly.
The database update error in de log that I noticed in the previous version is solved.
Played a lot of FLAC files, until now no problems.
squadjot
Post by squadjot »
So far no issues, thank you very much.
wurstpistole
Post by wurstpistole »
Thanks! Was me who reported this, got a bit annoying in my content folder.
GG76
Post by GG76 »
Hello I'm french and I speak very bad English. I use Ums 7.3.1 on several PCs to play my movies and music on my Samsung QE65Q7F. I can not read WAV files. PS media server works well with WAV but UMS does not recognize it. Can you help me ? Thank you GG76
terryxar
Post by terryxar »
Standalone was a great idea. The program is great but I had a lot of disconnections with 7.3.1 on my old Samsung 46es8000. Went back to 7.3.0 and things look a lot better (no disconnection so far).
