Bush DVB-T2 PVR MPEG4 Renderer, please can you add it
I have have been using UMS-7.31 via a Bush DVB-T2 PVR MPEG4 but the required renderer configuration file is not included in your distribution.
Following the instructions on your website, I have made up a renderer file which, at the moment, I add manually to the "renderers" directory inside the
UMS.app package every time it is updated.
Please could you add this renderer config file to your distribution.
I have included all log files, the new renderer config file and also the cut-down version of the user manual for the Bush DVB-T2 kit.
regards
Andrew
regards
Andrew
- Bush 2489502_R_D001_b.zip
- (662.72 KiB) Downloaded 548 times
- (2.97 MiB) Downloaded 545 times
Re: Bush DVB-T2 PVR MPEG4 Renderer, please can you add it
I've added a PR on your behalf. You can track the progress here.
Thanks for doing this.
I have also commented on the github link and added a icon file
