Sound too fast/shutters on Samsung TV
Hi All,
Tried to google my issue but without luck... I have Samsung TV UE46E6500 (it is using NoCD config file) and everything was running perfectly on UMS since 5.x versions untill 7.3.0. After updating it some movies have audio issues - audio is being played very fast comparing to the video and it sounds like it shutter. This issue usually appear on mkv files with DTS audio. I was trying to use diferent versions of same movie but this is not the solution...
Maybe you can help to trace my issue somehow and solve it.
- (81.24 KiB) Downloaded 309 times
Re: Sound too fast/shutters on Samsung TV
Hi marwoo, can you please let us know which version was the last one that worked for you? You said 7.3.0 is broken but I doubt that was the version that caused it, could you step backwards in versions?
