Problems with danish subtitles
For some reason Universal media player can't show the danish letters Æ,Ø,Å when i see a movie with danish subtitles. Instead it shows some weird symbols. Anyone have a solution?
Re: Problems with danish subtitles
Please can you follow the Forum rules written in red above and send the log? It seems that the danish language is not properly recognised.
Let me just add, i use danish subtitles on two different devices all the time, no problem.
I watch Norwegian subtitles with no problems with the same letters. This is clearly an encoding problem. Try to save your subtitles as UTF-8 with BOM and see if that helps. You can use any decent text editor like Notepad++ to open, convert and save text files like .srt.
If you are on Windows, good old Notepad will do. When you use "save-as" dialog you can choose the encoding from the dropdown.
