UMS does not run
enfield250
UMS does not run
Post by enfield250 »
Hello!
I'm quite new to this forum.
This morning I downloaded and installed UMS standalone 64 bit, using clean install.
When I click on the icon I just get the splash screen, and "loading".
If I open task manager USM doesn't show, I do however show Java running in the background.
I have uninstalled UMS and re-installed, but it just the same.
I'm running Win10 build 1803.
Any Ideas?
Cheers,
Re: UMS does not run
Hi enfield, please post logs, there are instructions near the bottom of this post viewtopic.php?f=9&t=556
