[Solved] 7.6.0 problem
nfelipe.gomes
Post by nfelipe.gomes »
Win7 x64, 7.6.0-x64 standalone, new clean profile.
Samsung UE32EH5307KX didn't detect any files shared in UMS. VLC player running on Android phone sees and plays all of it without problems. But after VLC's seek Samsung can find files but with broken folder structure and errors with many video files.
Re: 7.6.0 problem
Thanks for the report, does 7.5.0 work? Also logs would be useful. Also try using the "Force networking interface" option
nfelipe.gomes
Re: 7.6.0 problem
7.5.0 works fine, "Force networking interface" didn't help.
(81.92 KiB) Downloaded 607 times
pipin
Re: 7.6.0 problem
Post by pipin »
nfelipe.gomes wrote: Sat Nov 17, 2018 6:11 am Win7 x64, 7.6.0-x64 standalone, new clean profile.
Did you try "All files" on the Samsung? After the update my tv did not show any files or even the shared folders. After selecting "All Files" they were shown, even if I selected only "Video files".
Regards,
Jens
drakulis
Re: 7.6.0 problem
Post by drakulis »
@nfelipe.gomes and anybody else with Samsung E+ serie: Could you proceed with steps described here and check if it works for you?
nfelipe.gomes
Re: 7.6.0 problem
ums.jar 7.6.1-snapshot from github works, everything fine now.
Re: 7.6.0 problem
Thanks for letting us know, we will release the bug fix in the next version
