UMS getting run as a service to work 100%
i have come across a solution to get it to work on the latest release.
Download a version of PS3 media server pms-1.90.1-setup-full-x64 to extract the following file that is missing from the Universal media server installation package.
the file named: pms.jar is missing from UMS main folder, copy from the installation path of PS3 media server down to UMS folder installation path
example:
C:\Program Files (x86)\PS3 Media Server\pms.jar to UMS path.
now that the file is copied, open UMS interface and install as a service.
go to win32\service\ and open wrapper.conf file anf chagne the following settings.
wrapper.java.classpath.2=dms.jar to wrapper.java.classpath.2=pms.jar
the file is spelled wrong.
after this you can go back to Services int he OS and start the Digital Media Server. this shoudl start normally.
enjoy
example:
enjoy
Re: UMS getting run as a service to work 100%
update, i notice that the pms.jar doesn't work, used the UMS.jar that comes with the installation folder of UMS and rename the inclusion int he wrapper.conf file instead of PMS.jar to use UMS.jar
