[Solved] FFMPEG does segmentation fault
I've been on UMS 3 since the a2 version and since a5, the bundled FFMpeg executable is no longer working.
It just burps out "Segmentation fault" before returning to command line.
The last version that works for me is:
ffmpeg version N-54184-gcea8a00 Copyright (c) 2000-2013 the FFmpeg developers
built on Jun 25 2013 05:13:10 with gcc 4.6 (Debian 4.6.3-1)
I saw in the changelog that everything was going through ffmpeg now and that mplayer had been discarded.
I use the ffmpeg that works for me but I would like to have the up-to-date FFMpeg
Re: FFMPEG does segmentation fault
i use the buildin version in 3.0.0-final.
It dose give me segmentation fault on manual execution (on 64bit version of ubuntu) but It still works when streaming O_o
If you dont want to use it just re/move it from ums dir and install your ffmpeg onto your machine.
server: C2D [email protected] 3GB RAM
network: wired 1000MB/s
OS: Linux 13.10 64bit
this have been fix with 3.1.0
Re: [Solved] FFMPEG does segmentation fault
Yes, I have just seen that.
Working great now.
Thx!
Working great now.
Thx!
