panasonic TX-40FXX739 > no playback - Video files not supported
jojohio
Post by jojohio »
hello i want to use UMS with a panasonic TX-40FXX739. Connection works, but most of my files are not supported!?
What can I do?
jojohio
Re: panasonic TX-40FXX739 > no playback - Video files not supported
Post by jojohio »
ok, thank you. here it is!
(151.59 KiB) Downloaded 862 times
Sami32
Post by Sami32 »
It seem that AviSynth has been broken on the way.
So i suggest you to disable the AviSynth engines or try to use older version like UMS 6.7.4:
https://sourceforge.net/projects/unimed ... s/Windows/
If you still have similar issue, feel free to post a new log.
It looks like the version of AviSynth installed on the computer is too old for FFmpeg to use, since FFmpeg gives us a warning that it needs 2.6RC1+
Anyway AviSynth isn't really recommended, I suggest that you reinstall UMS using the "Clean install" checkbox and keep most things at their default settings, see if that works :)
jojohio
Post by jojohio »
no , sorry it didn't work.... I did a clean install- nothing happened. I Installed AviSynth_20160517_VC6.exe. again nothing ... Here another Log.pack Thank you very much for yout help!
(157.4 KiB) Downloaded 820 times
xyr
Post by xyr »
Try UMS version 7.4
I had the same "file not supported" problem on my Panasonic ST60 with the last few versions of UMS, so I decided to do some testing. I tried all the newer versions (clean install) until I got to 7.4 that works ok.
@jojohio it would be useful if you let us know whether 7.4 fixes it like xyr said. We have done some major changes and refactorings in 7.5 and 7.6 so unfortunately that brings some bugs, but we will work with you to fix them.
We also need to know which files are not working for you, because I see a lot of played files in the logs (16 of them) and I don't know which ones worked for you.
Thanks for your patience.
[email protected]
Post by [email protected] »
SubJunk wrote: Thu Dec 13, 2018 7:36 pm @jojohio it would be useful if you let us know whether 7.4 fixes it like xyr said. We have done some major changes and refactorings in 7.5 and 7.6 so unfortunately that brings some bugs, but we will work with you to fix them.
Hi, i had same issue, what i tryied:
Java HotSpot(TM) Client VM 1.8.0_191 (32-bit) by Oracle Corporation
OS: Microsoft Windows 10 build 17134 64-bit
CPU: Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz with 4 cores
Physical Memory: 7.9 GiB
Free Memory: 3.5 GiB
Maximum JVM Memory: 742.4 MiB
My TV is Panasonic TX-P50GT60 using Panasonic VIErA configuration
Install UMS version 8.0.0.A2 and Java 8 versions 162, 171, 172, 181, 191 - can play 1 movie from 10 attempts, after done watching - application crashes, cant install as service called Digital Media Server, doesnt even detect instaled as service and cant uninstall service - had use CMD line command SC delete <#> OR rename service name in wrappers conf. as new install
Install UMS version 7.7.1 and Java 8 versions 162, 171, 172, 181, 191 -can play 1 movie from 10 attempts, after done watching - application crashes, cant install as service called Digital Media Server, doesnt even detect instaled as service and cant uninstall service - had use CMD line command SC delete <#> OR rename service name in wrappers conf. as new install
Install UMS version 7.4.0 and Java 8 191 - everything looks good, can install as service called Universal Media Server, detect instaled as service - can be uninstalled, application doesnt crash
I have feeling, that after 7.5.0 i had issues - but have no proof, have to be tested.
One of the ordinary IT administrators
