WARN Could not parse VLC version, the version might be too low (< 2.0.2)
Any hints?
WARN Could not parse VLC version, the version might be too low (< 2.0.2) ???
vlc 3.0.4-1ubuntu0.2 amd64 is installed and works fine
Ubuntu 18.04 LTS, kernel 4.19.3, 64bit, UMS 7.6.2
/usr/bin/vlc --version:
VLC media player 3.0.4 Vetinari (revision 3.0.4-0-gf615db6332)
VLC-Version 3.0.4 Vetinari (3.0.4-0-gf615db6332)
Kompiliert von buildd auf lcy01-amd64-027.buildd (Oct 7 2018 01:20:32)
Kompiler: gcc version 7.3.0 (Ubuntu 7.3.0-27ubuntu1~18.04)
TRACE 2018-11-26 17:51:05.482 [SPW "vlc" consumer] net.pms.io.ListProcessWrapperConsumer Process output: VLC-Version 3.0.4 Vetinari (3.0.4-0-gf615db6332)
TRACE 2018-11-26 17:51:05.482 [SPW "vlc" consumer] net.pms.io.ListProcessWrapperConsumer Process output: Kompiliert von buildd auf lcy01-amd64-027.buildd (Oct 7 2018 01:20:32)
TRACE 2018-11-26 17:51:05.482 [SPW "vlc" consumer] net.pms.io.ListProcessWrapperConsumer Process output: Kompiler: gcc version 7.3.0 (Ubuntu 7.3.0-27ubuntu1~18.04)
TRACE 2018-11-26 17:51:05.482 [SPW "vlc" consumer] net.pms.io.ListProcessWrapperConsumer Process output: Dieses Programm kommt OHNE GEWÄHRLEISTUNG.
TRACE 2018-11-26 17:51:05.482 [SPW "vlc" consumer] net.pms.io.ListProcessWrapperConsumer Process output: Sie dürfen das Programm unter den Bedingungen der GNU General Public License weitergegeben;
TRACE 2018-11-26 17:51:05.482 [SPW "vlc" consumer] net.pms.io.ListProcessWrapperConsumer Process output: Für Details bitte die Datei COPYING ansehen.
TRACE 2018-11-26 17:51:05.482 [SPW "vlc" consumer] net.pms.io.ListProcessWrapperConsumer Process output: Geschrieben von der VideoLAN-Gruppe; zu sehen in der AUTHORS-Datei.
WARN 2018-11-26 17:51:05.483 [main] net.pms.encoders.VLCVideo Could not parse VLC version, the version might be too low (< 2.0.2) ???
- (88.33 KiB) Downloaded 388 times
