Issue with UMS 7.7.0 and PS4 playback with internal subs
jibi049
Post by jibi049 »
While I was trying to play this file I got the following error :
GET /get/146/The.Good.Place.S03E04.Jeremy.Bearimy.1080p.AMZN.WEB-DL.DDP5.1.H264-SiGMA.mkv_transcoded_to.ts HTTP/1.1
HEADER:
  Range: bytes=0-
  Host: 192.168.1.57:5001
  User-Agent: MediaPlayer/4.00 libhttp/6.20 (PlayStation 4)
  Connection: Keep-Alive
13:00:55 TRACE Asked stream chunk : TimeRange [start=null, end=null] of The.Good.Place.S03E04.Jeremy.Bearimy.1080p.AMZN.WEB-DL.DDP5.1.H264-SiGMA.mkv and player AviSynth/FFmpeg
13:00:55 TRACE Setting lastStartPosition from time-seeking: 0.0
13:00:55 DEBUG Starting transcode/remux of The.Good.Place.S03E04.Jeremy.Bearimy.1080p.AMZN.WEB-DL.DDP5.1.H264-SiGMA.mkv with media info: Container: MKV, Size: 1448441437, Video Bitrate: 8949836, Video Tracks: 1, Video Codec: h264, Duration: 0:21:34.720, Video Resolution: 1920 x 1080, Display Aspect Ratio: 16:9, Scan Type: Progressive, Frame Rate: 23.976, Frame Rate Mode: CFR, Matrix Coefficients: BT.709, AVC Level: 4, Audio Tracks: 1 [Id: 0, Language Code: Eng, Audio Codec: Enhanced AC-3, Bitrate: 640000, Channels: 6, Sample Frequency: 48000 Hz], Subtitle Tracks: 1 [id: 0, type: SUBRIP, subtitles track title from metadata: English (SDH), lang: Eng], DLNAThumbnail: [Format = JPEG, Resolution = 320×180, Size = 10159, DLNA Profile = JPEG_RES_320_180], Mime Type: video/x-matroska
13:00:55 TRACE Forcing short path name on D:\Séries\The Good Place\S03\The.Good.Place.S03E04.Jeremy.Bearimy.1080p.AMZN.WEB-DL.DDP5.1.H264-SiGMA.mkv
13:00:55 TRACE Looking for an audio track with lang: fre
13:00:55 TRACE Looking for an audio track with lang: eng
13:00:55 TRACE Matched audio track: Id: 0, Language Code: Eng, Audio Codec: Enhanced AC-3, Bitrate: 640000, Channels: 6, Sample Frequency: 48000 Hz
13:00:55 TRACE Searching for a match for: Eng with en and eng,*
13:00:55 TRACE Searching for a match for: Eng with fr and off
13:00:55 TRACE Searching for a match for: Eng with * and eng
13:00:55 TRACE Matched internal subtitles track: id: 0, type: SUBRIP, subtitles track title from metadata: English (SDH), lang: Eng
13:00:55 TRACE Searching for a match for: Eng with * and und
13:00:55 TRACE Switching from FFmpeg to MEncoder to transcode subtitles because the user setting is enabled.
13:00:55 TRACE Not muxing the video stream with tsMuxeR via MEncoder because the user setting is disabled
13:00:55 TRACE Using video bitrate limit from the general configuration (30 Mb/s)
13:00:55 TRACE Halving the video bitrate limit to 15000 kb/s
13:00:55 TRACE Adjusting the video bitrate limit to 14000 kb/s to make room for audio
13:00:55 DEBUG Creating pipe \\.\pipe\mencoder1545652855813
13:00:55 TRACE Successfully initialized buffer to 52,428,800 bytes.
13:00:55 DEBUG Caught exception: null
13:00:55 DEBUG Waiting for Windows names pipe connection "\\.\pipe\mencoder1545652855813"
13:00:55 TRACE
	at net.pms.io.ProcessWrapperImpl.<init>(ProcessWrapperImpl.java:105)
	at net.pms.io.ProcessWrapperImpl.<init>(ProcessWrapperImpl.java:88)
	at net.pms.io.ProcessWrapperImpl.<init>(ProcessWrapperImpl.java:67)
	at net.pms.encoders.MEncoderVideo.launchTranscode(MEncoderVideo.java:2478)
	at net.pms.encoders.FFMpegVideo.launchTranscode(FFMpegVideo.java:924)
	at net.pms.dlna.DLNAResource.getInputStream(DLNAResource.java:3476)
	at net.pms.network.RequestV2.dlnaMediaHandler(RequestV2.java:374)
	at net.pms.network.RequestV2.dlnaResourceHandler(RequestV2.java:338)
	at net.pms.network.RequestV2.answer(RequestV2.java:229)
	at net.pms.network.RequestHandlerV2.writeResponse(RequestHandlerV2.java:393)
	at net.pms.network.RequestHandlerV2.messageReceived(RequestHandlerV2.java:257)
	at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:70)
	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564)
	at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791)
	at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleUpstream(ChunkedWriteHandler.java:142)
	at org.jboss.netty.handler.codec.http.HttpChunkAggregator.messageReceived(HttpChunkAggregator.java:145)
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:296)
	at org.jboss.netty.handler.codec.frame.FrameDecoder.unfoldAndFireMessageReceived(FrameDecoder.java:459)
	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:536)
	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:435)
	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:559)
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:268)
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:255)
	at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:88)
	at org.jboss.netty.channel.socket.nio.AbstractNioWorker.process(AbstractNioWorker.java:108)
	at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:337)
	at org.jboss.netty.channel.socket.nio.AbstractNioWorker.run(AbstractNioWorker.java:89)
	at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:178)
	at org.jboss.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108)
	at org.jboss.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
Subtitle priority : en,eng,*;fr,off;*,eng;*,und
Seems that MEncoder doesnt like transcoding of the internal subtitles...
Is it possible to fix ?
Thank you
jibi049
Post by jibi049 »
I have some issues playing files with internal subtitles. If I disable subtitles the file plays.
See the attached logs (line 12804 - NullPointerException at Mencoder.launchTranscode)
Thanks !
(137.83 KiB) Downloaded 798 times
