After update (and clean install) nothing is working
Hej,
I'm using latest UMS to watch content on a Panasonic Viera TX-50DXW784. I had a fine working installation, only some UHD crashes, some others as green bars on top and buttom - but most of files are shown flawless!
I did an UMS update to the latest version, Unfortonally I have chosen "clean install". After restarting UMS no content is streamed to my TV. UMS is dounf by the tv, also the shared folders and content. I tried to start "test_movie_1080p.mkv" which is running fine on PC with vlc. UMS did not shows me the "preview" while I am on the file, after try to start the file some seconds later I get an "File is not readable" (in german "Datei ist nicht lesabar").
I do not know what IÄm doing wrong.
The debug files are enclosed.
Tom!
Tom!
- (74.97 KiB) Downloaded 718 times
Re: After update (and clean install) nothing is working
using the 7.3.1 or 7.4.0 version should make you able to avoid that bug:
https://sourceforge.net/projects/unimed ... s/Windows/
Hoping that fitted your need.
