New to UMS
TreyAK
New to UMS
Post by TreyAK »
I cant tell if I'm doing this right, i read all the posts on the GitHub and tested most if not all the steps and different security guides. It works perfectly thus far i just cant seem to make it show up only on one TV , i tried the whitelist steps aswell as the pin code and head folder steps and it seems to show up in every TV in my home. Any advice/help would be greatly appreciated. Also is there away to control playback of the video file?
atamariya
Re: New to UMS
Post by atamariya »
Whitelist should work. You can share the logs for further help.
squadjot
Re: New to UMS
Post by squadjot »
You can hack a way to do it by device UUID.
Unwanted.conf - https://www.universalmediaserver.com/fo ... php?t=8558
Using this method is safe as it is not based on IP (which can change)
