mkv movies are shown in 4/3 instead of 16/9
boernerf
Post by boernerf »
I'm new to UMS.
for pictures and mpeg files it works well, even 16/9.
But all my mkv files are not shown correct, instead of 16/9, its shrink to 4/3, and 4/3 is shrink more small on the TV.
The TV is a Panasonic 55FZW804
I tried some different settings which I found in the forum, but nothing helps.
Could u pls recommend some settings which hopefully work.
Thanks a lot!
regards, Frank
(77.53 KiB) Downloaded 542 times
boernerf
Re: mkv movies are shown in 4/3 instead of 16/9
Post by boernerf »
yes, all mkv files
Surfy
Post by Surfy »
Seems the same as for me. Read
https://www.universalmediaserver.com/fo ... =9&t=13342, please.
Try Version 7.5.0.
Regards, ...
