[Solved] Shutdown plugin
Razorback255
Post by Razorback255 »
Hi
Have been trying to find this everywhere but no luck. The only link I have is -
http://ps3mediaserver.org/forum/viewtop ... =12&t=6117
isduffman
Re: Shutdown plugin
Post by isduffman »
i have found it on my Backup Data ;) but UMS dont support plugin´s .
Edit : New Link ;) https://www41.zippyshare.com/v/GFhI7Hcs/file.html
ps:if you get it please let me know;)
Razorback255
Re: Shutdown plugin
Got it thanks. Yea, I think i'll go back to PMS now :D
isduffman
Re: Shutdown plugin
Post by isduffman »
Razorback255 wrote: Tue Apr 30, 2019 10:56 pm Got it thanks. Yea, I think i'll go back to PMS now :D
NP buddy
pipin
Re: Shutdown plugin
Post by pipin »
I tried this too, only for the shutdown plugin.
With Ps3 Media Server
https://osdn.net/projects/sfnet_pms-mlx ... l-x64.exe/
But PMS does not work on Windows 10 for me without flaws.
Cant see the shared folders nor the plugins on the tv.
Regards,
Jens
Re: Shutdown plugin
It probably wouldn't be too hard to re-add support for plugins if someone is motivated to do that. I would support it.
pipin
Re: Shutdown plugin
Post by pipin »
SubJunk wrote: Fri Dec 11, 2020 1:22 pm It probably wouldn't be too hard to re-add support for plugins if someone is motivated to do that. I would support it.
Maybe it would be sufficient to add this as a feature?
My solution is now a very short (15 minutes) time for the pc to go to sleep.
And I do wake up the pc over tablet or phone with an app WOLdroid which sends magic packets to the network card.
The network card is set to only wake up with magic packets.
Regards,
Jens
Re: Shutdown plugin
I would support adding it as a feature for sure. I wonder if we can get the code for that old plugin, that might help us add it
pipin
Re: Shutdown plugin
Post by pipin »
SubJunk wrote: Tue Feb 02, 2021 4:14 pm I would support adding it as a feature for sure. I wonder if we can get the code for that old plugin, that might help us add it
I have the plugin here, but its buried deep in my pc. I will search for it.
Regards,
Jens
Nierewa
Re: Shutdown plugin
Post by Nierewa »
Here's the shutdown plugin
I used PS3 Media Server but with VLC Player it always activates the plöugin and shutdown my PC before I can watch a video file.
I wonder if USM works better here...?
shutdown.zip
(9.58 KiB) Downloaded 447 times
