Version 9.0.0 released
General:
We no longer require Java installation on any operating system, ever. In addition, there are significant stability and connectivity improvements, as well as more bugfixes and performance improvements.
You can download it from the front page or install it via Docker with:
docker pull universalmediaserver/ums
Changes since 8.2.0
  • General:
    • We no longer require Java installation on any operating system
    • Adds UMS to Windows Firewall exceptions on install
    • Added new renderer setting vbd (video bit depth) to allow filetype-specific bit-depth support configuration
    • Fixed filename prettifying not displaying episode names and other related problems
    • Fixed the PrependTrackNumbers renderer setting (thanks, tcely!)
    • Fixed transcoding when using our Docker image (thanks, tcely!)
    • Fixed startup crash when invalid characters are in the OS Path
    • Fixed adding unsupported files to the database
  • Renderers:
    • Improved support for TrueHD videos on Samsung UHD TVs
  • Languages:
    • Fixed broken "hide engines" string
    • Updated translations via Crowdin:
      • Chinese Simplified (100%)
      • Chinese Traditional (94%)
      • Croatian (20%)
      • Czech (100%)
      • Danish (89%)
      • Finnish (32%)
      • French (100%)
      • German (100%)
      • Hungarian (68%)
      • Italian (98%)
      • Japanese (100%)
      • Norwegian (89%)
      • Polish (100%)
      • Portuguese (Brazilian) (100%)
      • Romanian (100%)
      • Russian (93%)
      • Slovak (88%)
      • Spanish (96%)
      • Swedish (93%)
      • Thai (11%)
  • Dependencies:
    • Updated Chromecast api-v2 to 0.11.0
    • Updated fm.last coverartarchive-api to 2.1.1
    • Updated Git Commit ID Plugin to 2.2.4
    • Updated icu4j to 64.2
    • Updated JNA to 5.3.1
    • Updated JUnit to 5.2.0
    • Updated Maven Compiler Plugin to 3.8.0
    • Updated Maven Enforcer Plugin to 3.0.0-M1
    • Updated Maven Javadoc Plugin to 3.0.1
    • Updated Maven Site Plugin to 3.7
    • Updated Metadata Extractor to 2.12.0 for improved image parsing performance
    • Updated Oshi to 3.13.3
    • Updated Surefire to 2.22.2
Changes since 9.0.0-b2
  • General:
    • Better cleanup of install directory on install/uninstall on Windows
    • Fixed track numbers not prepending in Media Library
  • Renderers:
    • Croatian (20%)
    • Czech (100%)
    • Danish (89%)
    • Finnish (32%)
    • Japanese (100%)
    • Polish (100%)
    • Russian (93%)
    • Slovak (88%)
    • Thai (11%)
  • Dependencies:
Notes:
  • The Windows releases work on Windows Vista onwards.
pipin
Re: Version 9.0.0 released
Post by pipin »
Thanks for the release.
Forum seems to work now.
Regards,
Jens
pipin
Post by pipin »
Installations needs a very long time to start.
https://sourceforge.net/projects/unimed ... s/Official Releases/Windows/
beta 2 is missing here
Regards,
Jens
erickps4
Post by erickps4 »
hi subjunk i had a problem login with my old account so i'm using this new one. thanks for the release i'll check it out for a couple of a days let know how is working on the ps4 pro media player.
have a nice weekend :D
Chuck_Arch_Ums
Post by Chuck_Arch_Ums »
Tested this release on up to date x64 Arch Linux and it work great, making it my every day version for my laptop and pc.
Stream movie with or without sub and/or transcoding and all went well.
Music and picture too.
Thanks,
Mitch_
Post by Mitch_ »
I'm testing UMS on Arch Linux with the included Java installation, but it requires a few changes to work.
I opened an issue on GitHub with my changes (#1835)
Chuck_Arch_Ums
Mitch_ wrote: Mon Sep 09, 2019 12:56 pm I'm testing UMS on Arch Linux with the included Java installation, but it requires a few changes to work.
Indeed, if I remove my java package installed from my distro you need to edit UMS.sh because it does not find java.
Rhialto
Post by Rhialto »
rdsparla
Post by rdsparla »
The latest version of Universal Media server 9.0.0 does not install the plugin folder to be implemented in Windows 10. Is there no longer that possibility, or is there another way to activate them? Thank you
pipin
Post by pipin »
rdsparla wrote: Tue Sep 17, 2019 8:32 pm The latest version of Universal Media server 9.0.0 does not install the plugin folder to be implemented in Windows 10. Is there no longer that possibility, or is there another way to activate them? Thank you
Plugins are not supported any more. But support was dropped some time ago.
Regards,
Jens
