[Solved] Unhandled exception while resolving
POIZ
Post by POIZ »
I have a lot of these mistakes.
Two complete Series will not be shown by my TV.
The log say this: Unhandled exception while resolving...
for other series there is no Problem.
Debug is attached. Trace mode did not work. apparently there is no folder research in this mode.
(360.86 KiB) Downloaded 1058 times
valib
Re: Unhandled exception while resolving
Post by valib »
It is a bug but you can use the the "standard" file naming and rename your files like
tvr_criminal_minds_s09e07_720p.mkv
or
 tvr.criminal.minds.s09e07.720p.mkv
POIZ
Post by POIZ »
What is the difference and What do I have to change?
The location of the number of the season and episode?
Thx 4ur quick answer
valib
Post by valib »
Only to change hyphens in the file names to dots or underscores. Than UMS will pretify them correctly.
POIZ
Post by POIZ »
If you wanna know:
Criminal Minds i renamed like this:
"Y:\Downloads\Serien\Criminal.Minds\Season_01\1x01_Der.Abgrund.mkv"
Homeland like this:
"Y:\Downloads\Serien\Homeland\Season_01\S01E01_Der.Verdacht.mkv"
i terminated all hyphens. Criminal Minds was good than. Homeland still makes a mistake for all episodes.
After changing S01E01 to 01x02 Homeland was good too.
We have a fix coming up for this in the next version, thanks for reporting it
