Info about net.pms.dlna.RealFile
sapsa
Post by sapsa »
Should I worry, what is this about ?
INFO  2013-11-28 05:50:40.297 [New I/O worker #3] Node (net.pms.dlna.RealFile) already has an ID (0$1$6), which is overridden now. The previous parent node was: RecentlyPlayed [id=1, name=Recently Played, full path=0$1, ext=null, discovered=false]
INFO  2013-11-28 05:50:40.297 [New I/O worker #3] Node (net.pms.dlna.RealFile) already has an ID (0$1$7), which is overridden now. The previous parent node was: RecentlyPlayed [id=1, name=Recently Played, full path=0$1, ext=null, discovered=false]
INFO  2013-11-28 05:50:40.297 [New I/O worker #3] Node (net.pms.dlna.RealFile) already has an ID (0$1$9), which is overridden now. The previous parent node was: RecentlyPlayed [id=1, name=Recently Played, full path=0$1, ext=null, discovered=false]
INFO  2013-11-28 05:50:40.298 [New I/O worker #3] Node (net.pms.dlna.RealFile) already has an ID (0$1$11), which is overridden now. The previous parent node was: RecentlyPlayed [id=1, name=Recently Played, full path=0$1, ext=null, discovered=false]
INFO  2013-11-28 05:50:40.298 [New I/O worker #3] Node (net.pms.dlna.RealFile) already has an ID (0$1$12), which is overridden now. The previous parent node was: RecentlyPlayed [id=1, name=Recently Played, full path=0$1, ext=null, discovered=false]
INFO  2013-11-28 05:50:40.298 [New I/O worker #3] Node (net.pms.dlna.RealFile) already has an ID (0$1$13), which is overridden now. The previous parent node was: RecentlyPlayed [id=1, name=Recently Played, full path=0$1, ext=null, discovered=false]
INFO  2013-11-28 05:50:40.299 [New I/O worker #3] Node (net.pms.dlna.RealFile) already has an ID (0$1$15), which is overridden now. The previous parent node was: RecentlyPlayed [id=1, name=Recently Played, full path=0$1, ext=null, discovered=false]
INFO  2013-11-28 05:50:40.299 [New I/O worker #3] Node (net.pms.dlna.RealFile) already has an ID (0$1$17), which is overridden now. The previous parent node was: RecentlyPlayed [id=1, name=Recently Played, full path=0$1, ext=null, discovered=false]
INFO  2013-11-28 05:50:40.300 [New I/O worker #3] Node (net.pms.dlna.RealFile) already has an ID (0$1$19), which is overridden now. The previous parent node was: RecentlyPlayed [id=1, name=Recently Played, full path=0$1, ext=null, discovered=false]
INFO  2013-11-28 05:50:40.300 [New I/O worker #3] Node (net.pms.dlna.RealFile) already has an ID (0$1$21), which is overridden now. The previous parent node was: RecentlyPlayed [id=1, name=Recently Played, full path=0$1, ext=null, discovered=false]
server: C2D [email protected] 3GB RAM
network: wired 1000MB/s
OS: Linux 13.10 64bit
DeFlanko
Contact:
Re: Info about net.pms.dlna.RealFile
Post by DeFlanko »
I think its your recently played folder updating itself... Should be ok if no errors or issues were caused.
sapsa
Post by sapsa »
DeFlanko wrote:I think its your recently played folder updating itself... Should be ok if no errors or issues were caused.
Probably thats right.
Thanks for posting this, sapsa. In future releases it won't show up like that.
