[Solved] Stability issues in versions later than v6.8.0 (v9.1.0 included)
Re: Stability issues in versions later than v6.8.0 (v9.1.0 included)
We will need logs to help you. please follow the link in the red banner above.
Thanks for the logs. Please also attach logs from 6.8.0 so we can see what differences might be causing your problems.
Re: All versions after 6.8.0 do not work properly.
I'm aware if this, but I think the developers are content with how it works. It does seem to work for some, so I assume that it's a bit random if you are hurt by one of the bugs introduced in 7.0 or thereafter.
We are certainly not content with bugs and most of my development time on this project is spent fixing them. Sometimes bugs fall through the cracks or fail to get prioritized correctly and I apologize for that. I appreciate you making a new topic for this to remind me. Let's try to fix it together.
I'll see if I can merge this topic into https://www.universalmediaserver.com/fo ... hp?t=13845 and continue it there
I have started to look into this and I'm interested to get your feedback on a test file. Please try again to play the first file using https://www.universalmediaserver.com/up ... 690b03.exe
If it still doesn't work, please attach new logs and I will continue investigating
