Samsung Q7 transcode settings for unsupported formats
Re: Samsung Q7 transcode settings for unsupported formats
You can find the "bundled" renderer configurations here: https://github.com/UniversalMediaServer ... /renderers
It doesn't seem to be a Q7 profile, but there seems to be for Q6 and Q9. The differences are probably relatively small, so you could just modify one of them. It's pretty simple to modify the "supported" lines. If you read a bit on this forum, you will find information, and some documentation also exists in "DefaultRenderer.conf". Basically, anything that isn't listed as "supported" is transcoded, so to make sure it transcodes AVI just make sure it's not listed as "supported".
