issues running 3.0.0
Monica Jae
Post by Monica Jae »
The debug log i attach is the latest which should demonstrate the issues i am dealing with when trying to play a file. Honestly, i don't even know where to begin, but all i know is that when i select a file to play it basically hangs at accessing file. There isn't even a "preview" thumbnail as there usually is that i'm used to. Just black, and many lines of "error parsing file" which i really don't understand :)
eums_dbg.zip
(791.02 KiB) Downloaded 439 times
DeFlanko
Contact:
Re: issues running 3.0.0
Post by DeFlanko »
Can you download and run the lastest version and see if that resolves your issue?
If not please attach those logs, in trace, to this same thread.
Monica Jae
well, the reason i'm running this is because subjunk suggested it when i couldn't get the newest version to work. but yeah, i guess i got nothing better to do, so i'll dl the newest again and install that.
DeFlanko
Contact:
Post by DeFlanko »
Monica Jae wrote:well, the reason i'm running this is because subjunk suggested it when i couldn't get the newest version to work. but yeah, i guess i got nothing better to do, so i'll dl the newest again and install that.
well i didn't know that part...
i did find some exception errors in your log though:
RROR 2013-11-27 01:36:48.396 [main] A serious error occurred during PMS init
	at org.jboss.netty.channel.group.DefaultChannelGroup.add(DefaultChannelGroup.java:115) ~[ums.jar:3.0.0]
	at org.jboss.netty.channel.group.DefaultChannelGroup.add(DefaultChannelGroup.java:39) ~[ums.jar:3.0.0]
	at net.pms.network.HTTPServer.start(HTTPServer.java:133) ~[ums.jar:3.0.0]
	at net.pms.PMS.init(PMS.java:704) [ums.jar:3.0.0]
	at net.pms.PMS.createInstance(PMS.java:1061) [ums.jar:3.0.0]
	at net.pms.PMS.main(PMS.java:1157) [ums.jar:3.0.0]
TRACE 2013-11-27 01:47:31.168 [New I/O worker #16] Adding new child "R.I.P.D..2013.1080p.BluRay.x264.YIFY.mp4" with class "net.pms.dlna.RealFile"
TRACE 2013-11-27 01:47:31.169 [New I/O worker #16] Format "mp4" failed to match support line f:mpegps|mpegts   v:mpeg1|mpeg2|mp4|h264   a:ac3|lpcm|aac|mpa   m:video/mpeg
TRACE 2013-11-27 01:47:31.169 [New I/O worker #16] Format "mp4" failed to match support line f:avi|divx        v:mp4|divx|mjpeg         a:mp3|lpcm|mpa|ac3   m:video/divx       qpel:yes|no   gmc:0
TRACE 2013-11-27 01:47:31.169 [New I/O worker #16] Format "mp4" failed to match support line f:wmv             v:wmv|vc1                a:wma                m:video/x-ms-wmv                         n:2
TRACE 2013-11-27 01:47:31.169 [New I/O worker #16] Format "mp4" failed to match support line f:wav     m:audio/wav        n:6   a:dts|lpcm   s:48000
TRACE 2013-11-27 01:47:31.169 [New I/O worker #16] Format "mp4" failed to match support line f:wav     m:audio/wav        n:2                s:48000
TRACE 2013-11-27 01:47:31.169 [New I/O worker #16] Format "mp4" failed to match support line f:mp3     m:audio/mpeg       n:2
TRACE 2013-11-27 01:47:31.169 [New I/O worker #16] Format "mp4" failed to match support line f:aac     m:audio/x-m4a      n:2   a:(?!alac).+
TRACE 2013-11-27 01:47:31.169 [New I/O worker #16] Format "mp4" failed to match support line f:wma     m:audio/x-ms-wma   n:2
TRACE 2013-11-27 01:47:31.170 [New I/O worker #16] Format "mp4" failed to match support line f:atrac   m:audio/x-oma      n:2
TRACE 2013-11-27 01:47:31.170 [New I/O worker #16] Format "mp4" failed to match support line f:jpg    m:image/jpeg
TRACE 2013-11-27 01:47:31.170 [New I/O worker #16] Format "mp4" failed to match support line f:png    m:image/png
TRACE 2013-11-27 01:47:31.170 [New I/O worker #16] Format "mp4" failed to match support line f:gif    m:image/gif
TRACE 2013-11-27 01:47:31.170 [New I/O worker #16] Format "mp4" failed to match support line f:tiff   m:image/tiff
TRACE 2013-11-27 01:47:31.170 [New I/O worker #16] File "R.I.P.D..2013.1080p.BluRay.x264.YIFY.mp4" can be transcoded
and it looks like the CONF your using failed to match up to MP4 media... which is weird.
