UMS 9.3.0
davey64
UMS 9.3.0
Post by davey64 »
Have downloaded this new version on two Macs one running macOS Sierra 10.12.6 and macOS 10.14.6 on opening the resulting dmg I get an error.
The following disk images couldn't be opened
UMS-9.3.0.dmg. no mountable file systems
Can you double-check that the download for Mac is viable. As I say downloaded twice to two different macOS's same error in both.
Screen Shot 2020-02-27 at 12.47.45.jpg (33.46 KiB) Viewed 8303 times
davey64
Re: UMS 9.3.0
Post by davey64 »
So just to add to my earlier post I have noticed that the UMS-9.3.0.dmg available from the front page of https://www.universalmediaserver.com by clicking on the Apple icon is only 89.5MBs and comes up with the error
as mentioned before.
However from the Source Forge page https://sourceforge.net/projects/unimed ... 0Releases/ the UMS-9.3.0.dmg is 187MBs and this does open and install.
So can you guys check this and resolve the incorrect download from the https://www.universalmediaserver.com front page.
Screen Shot 2020-03-01 at 08.23.54.jpg (29.92 KiB) Viewed 8268 times
Screen Shot 2020-03-01 at 08.23.41.jpg (31.9 KiB) Viewed 8268 times
