UMS Instances in Windows 10
Hi, i'm new with UMS, i have just 3 months using the program, actually 9.0.0 and 9.0.1, i havent updated because that caused me some problems, but this 2 builds works fine for me (Ps4, XBox, PC, Android/vlc, i tried 2 Bravia tv's but that's other problem).
My problem is, i been trying to run 2 instances of UMS so i can filter the content and connect 2 different interfaces, i have unchecked the box of "Execute 1 instance of UMS", click again to open UMS, it opens the "Welcome page" but it get stuck there, i don't know if i am doing something wrong, if Windows is the problem and it's not leting me open 2 services from the same program.
If someone can help me, thank you so much, if someone already asked this, sorry, i didn't find it.
Thank you.
PD: i'm going to add the trace but for what i see, this doesn't show up in the register of UMS.
Thank you.
- (21.8 KiB) Downloaded 286 times
Re: UMS Instances in Windows 10
To run two instances you must configure two different "profiles". These profiles must be in different folders, so that the database, temporary files and configuration files are separate. In addition, you must make sure that these two configurations use different TCP/IP ports. Finally, you must start the instance that should not run using the "default" profile location using command line arguments that specify the alternative profile location.
Ok, so, i need edit the UMS.conf, change folders and ports there, then, i suppose open cmd and run the second instance.Nadahar wrote: ↑Mon Apr 06, 2020 9:28 am To run two instances you must configure two different "profiles". These profiles must be in different folders, so that the database, temporary files and configuration files are separate. In addition, you must make sure that these two configurations use different TCP/IP ports. Finally, you must start the instance that should not run using the "default" profile location using command line arguments that specify the alternative profile location.
I will try this tonight, thank you.
