Version 9.4.1 released
General:
This release is mostly for macOS users to fix broken transcoding but also updates translations and bumps dependencies.
We are busy preparing our next beta which improves and extends our metadata, allowing for things like recommendations, genres, ratings from major sources, etc. as well as remote access.
Download:
You can download it from the front page, our other official mirrors, or install it via Docker with:
docker pull universalmediaserver/ums
Changes since 9.4.0
    • Bulgarian (93%)
    • Czech (100%)
    • Danish (99%)
    • Finnish (99%)
    • French (99%)
    • Hebrew (21%)
    • Italian (100%)
    • Polish (99%)
    • Portuguese (99%)
    • Portuguese (Brazilian) (99%)
    • Spanish (100%)
    • Swedish (100%)
    • Ukrainian (23%)
  • Dependencies:
    • Updated FFmpeg on macOS to fix a startup bug
    • Updated JUnit5 to 5.6.1
    • Updated Maven Javadoc plugin to 3.2.0
    • Updated Maven Assembly plugin to 3.2.0
Notes:
  • The Windows releases work on Windows Vista onwards.
