Samsung Soundbar MS 650
ancalimon
Post by ancalimon »
Is it possible to write a renderer for this device?
It uses a the renderer Samsung-CD.conf
I can see that there is a renderer for Samsung Soundbar MS 750. Maybe I can write a new one using that as a basis. Can someone help me?
I tried creating one for ms650 by modifying the one for ms750 by changing this line:
UserAgentSearch = Samsung Soundbar MS750
into reported name of device:
UserAgentSearch = [AV] Samsung Soundbar MS650
But it did not work.
Re: Samsung Soundbar MS 650
Using the the conf for the MS750 is a good start, it probably will have the same capabilities. If the reported UserAgentSearch is "[AV] Samsung Soundbar MS650", I would change that line in the config to just
UserAgentSearch = Samsung Soundbar MS650
also that config has a loading priority so that it overides the default Samsung-CD.conf, if UMS can can match the user agent correctly it will use that one.
We will need logs though to help any more if that doesn't work.
ancalimon
Post by ancalimon »
Here is the tracelogs for Samsung MS650
(149.55 KiB) Downloaded 1052 times
I have attached the logs as told.
Did you try making a conf? I don't see any config for the MS650 getting loaded.
If you are basing it in the MS750 conf, copy that and rename to Samsung-Soundbar-MS650.conf,
then change the RendererName to match and make sure it is detected by making sure the UserAgentSearch is correct
the important part to look for is
DEBUG 2020-04-18 17:06:18.396 [cling-9] net.pms.network.UPNPHelper New renderer found: "[AV] Samsung Soundbar MS650" with dlna details: {friendlyName=[AV] Samsung Soundbar MS650, address=192.168.1.5, udn=uuid:af66011d-0edf-4c87-810d-dcee1965f55b, manufacturer=Samsung Electronics, modelName=HW-MS650, modelNumber=AllShare1.0, modelDescription=Samsung SOUNDBAR DMR, manufacturerURL=http://www.samsung.com/sec, modelURL=http://www.samsung.com/sec}
using
should work
ancalimon
Post by ancalimon »
It still loads the Samsung-NotCD.conf file even after creating the attached
(975 Bytes) Downloaded 991 times
file and putting it inside C:\Program Files (x86)\Universal Media Server\renderers
Try setting the priority to 2, and do some more trace logs
ancalimon
Post by ancalimon »
I have attached the new tracelogs after setting the priority of the config file to 2.
(48.37 KiB) Downloaded 961 times
Looks like it is still matching the Samsung-NotCD.config, but I do see that your config is getting loaded at startup. Could you post your config as since it wasn't used it wasn't included in the zip file.
ancalimon
Post by ancalimon »
Is it this file?
UMS.conf
(59.6 KiB) Downloaded 898 times
If you are talking about MS650 config file, it is a few posts above. The only thing I changed is changing priority from 1 to 2.
Sorry forgot that you already posted it :oops:
I don't see why it is not matching it, even if something else had a higher priority, setting it to 2 should make it take over.
Try setting UserAgentSearch to just MS650 see if that does anything
