Thmubnails for folders
Can UMS display a thumbnail image for folders? If so, what is the format for the image name?
Re: Thmubnails for folders
I dont recall that function. Folders use static image.
server: C2D [email protected] 3GB RAM
network: wired 1000MB/s
OS: Linux 13.10 64bit
Try folder.jpg? I know there was the discussion in past but it was about PS3 which doesn't support folder thumbnails anyway (so not sure if UMS supports it or not as I have renderers without this support)
I saw some other references to folder.jpg here and at the old ps3mediaserver forum, but couldn't find a clear explanation.ExSport wrote:Try folder.jpg? I know there was the discussion in past but it was about PS3 which doesn't support folder thumbnails anyway (so not sure if UMS supports it or not as I have renderers without this support)
Now, I did put them in the alternate video art directory. I can try dropping them into the actual folder. I did not try 'folder.jpg'. I'll add that too.
