Suddenly UMS 3.3.0 doesn't work anymore...
I am using 3.3.0 and today suddenly I started to receive error on files I was able to opne yesterday.
After a few seconds I receive a "network error" and DLNA protocol on PS3 and I can't play the files anymore.
Attached the debug files.
Video is an avi file
XviD ISO MPEG-4
0x0055 MPEG-1 Layer 3 - 48000Hz 128 kb/s tot , Stereo
I already restarted and rebooted the UMS pc and the PS3
Thx!
XviD ISO MPEG-4
Thx!
- (182.15 KiB) Downloaded 478 times
Re: Suddenly UMS 3.3.0 doesn't work anymore...
Hello Gentlemen,
I also updated to 3.3.0 and Its a nonstop error galore in the Wrapper version (Service) and normal version.
Worked fine before the update.. Now crashes almost on every file (heavy stuttering while displaying videos then crashes).
I have tried to update JAVA and moving to a x64 wrapper version with X64 java, and still the same errors.
Upon updating, the first thing I noticed.. was that the 32bit version of Java crashing due of "out of memory" errors. (using the default value, increasing anything higher than 1200 caused a crash which is a known limitation of the 32bit version)
I also use the PS3 as my primary DLNA device to display content.
Video Info of the files that crash with a 100% sure ratio(didn't before the update):
External SRT used.
Internal SRT USED in this file:
DXDIAG CODE:
(edit)
Reinstalled everything clean, used 1,200Mb as default this time, installed as service.. same error, out of memory after some studdering in any of the files mentioned on top..
External SRT used.
D : 1
Format : AVC
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 9 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 43mn 1s
Bit rate : 2 424 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.110
Stream size : 746 MiB (83%)
Writing library : x264 core 140 r2377 1ca7bb9
Encoding settings : cabac=1 / ref=9 / deblock=1:-2:-2 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=16 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Matrix coefficients : BT.709
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 43mn 1s
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 138 MiB (15%)
Default : Yes
Forced : No
D : 1
Format : AVC
Muxing mode : Header stripping
Duration : 1h 45mn
Nominal bit rate : 2 000 Kbps
Width : 960 pixels
Height : 720 pixels
Display aspect ratio : 4:3
Frame rate : 24.000 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.121
Title : 4.1 The ABC Murders 720p HighCode
Writing library : x264 core 120
Encoding settings : cabac=1 / ref=9 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=0.80:0.00 / mixed_ref=1 / me_range=64 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=10 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=120 / rc=2pass / mbtree=1 / bitrate=2000 / ratetol=1.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:2.00
Language : English
Default : Yes
Forced : No
Color primaries : BT.709
Transfer characteristics : BT.709
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : A_AAC
Duration : 1h 45mn
Channel(s) : 2 channels
Channel positions : Front: L R
Language : English
Default : Yes
Forced : No
Time of this report: 12/17/2013, 22:17:06
Machine name: XXNAS
Operating System: Windows Server 2008 R2 Standard 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130828-1532)
Language: English (Regional Setting: English)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: To be filled by O.E.M.
BIOS: BIOS Date: 03/23/12 19:41:27 Ver: 04.06.05
[b]Processor: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz (4 CPUs)[/b], ~5.9GHz (down-clocked to 2.5 without turbo to save energy)
[b] Memory: 8192MB RAM[/b]
Available OS Memory: 8022MB RAM
Page File: 1724MB used, 22338MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
[b] Java installed (Version 7 Update 45).[/b]
(edit)
INFO | jvm 1 | 2013/12/17 22:58:37 | INFO 2013-12-17 22:58:37.340 [New I/O worker #6] Checking shared folder: F:\mp3
INFO | jvm 1 | 2013/12/17 22:59:12 | INFO 2013-12-17 22:59:11.895 [StartPlaying Event] Started playing Agatha Christie's Poirot - 4x01 - The A.B.C. Murders.mkv on your PlayStation 3
INFO | jvm 1 | 2013/12/17 23:04:44 | INFO 2013-12-17 23:04:44.102 [pool-734-thread-2] Exception in thread "pool-734-thread-2" java.lang.OutOfMemoryError: Java heap space
INFO | jvm 1 | 2013/12/17 23:04:44 | INFO 2013-12-17 23:04:44.103 [pool-734-thread-2] at java.awt.image.DataBufferByte.<init>(Unknown Source)
INFO | jvm 1 | 2013/12/17 23:04:44 | INFO 2013-12-17 23:04:44.104 [pool-734-thread-2] at java.awt.image.Raster.createInterleavedRaster(Unknown Source)
INFO | jvm 1 | 2013/12/17 23:04:44 | INFO 2013-12-17 23:04:44.104 [pool-734-thread-2] at java.awt.image.BufferedImage.<init>(Unknown Source)
INFO | jvm 1 | 2013/12/17 23:04:44 | INFO 2013-12-17 23:04:44.104 [pool-734-thread-2] at net.coobird.thumbnailator.resizers.ProgressiveBilinearResizer.resize(Unknown Source)
INFO | jvm 1 | 2013/12/17 23:04:44 | INFO 2013-12-17 23:04:44.105 [pool-734-thread-2] at net.coobird.thumbnailator.resizers.Resizers.resize(Unknown Source)
INFO | jvm 1 | 2013/12/17 23:04:44 | INFO 2013-12-17 23:04:44.105 [pool-734-thread-2] at net.coobird.thumbnailator.makers.ThumbnailMaker.makeThumbnail(Unknown Source)
INFO | jvm 1 | 2013/12/17 23:04:44 | INFO 2013-12-17 23:04:44.105 [pool-734-thread-2] at net.coobird.thumbnailator.makers.FixedSizeThumbnailMaker.make(Unknown Source)
INFO | jvm 1 | 2013/12/17 23:04:44 | INFO 2013-12-17 23:04:44.105 [pool-734-thread-2] at net.coobird.thumbnailator.Thumbnailator.createThumbnail(Unknown Source)
INFO | jvm 1 | 2013/12/17 23:04:44 | INFO 2013-12-17 23:04:44.105 [pool-734-thread-2] at net.coobird.thumbnailator.Thumbnails$Builder.toFile(Unknown Source)
INFO | jvm 1 | 2013/12/17 23:04:44 | INFO 2013-12-17 23:04:44.106 [pool-734-thread-2] at net.pms.dlna.DLNAMediaInfo.parse(DLNAMediaInfo.java:704)
INFO | jvm 1 | 2013/12/17 23:04:44 | INFO 2013-12-17 23:04:44.106 [pool-734-thread-2] at net.pms.formats.Format.parse(Format.java:268)
INFO | jvm 1 | 2013/12/17 23:04:44 | INFO 2013-12-17 23:04:44.106 [pool-734-thread-2] at net.pms.dlna.RealFile.resolve(RealFile.java:193)
INFO | jvm 1 | 2013/12/17 23:04:44 | INFO 2013-12-17 23:04:44.106 [pool-734-thread-2] at net.pms.dlna.DLNAResource.run(DLNAResource.java:962)
INFO | jvm 1 | 2013/12/17 23:04:44 | INFO 2013-12-17 23:04:44.107 [pool-734-thread-2] at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO | jvm 1 | 2013/12/17 23:04:44 | INFO 2013-12-17 23:04:44.107 [pool-734-thread-2] at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO | jvm 1 | 2013/12/17 23:04:44 | INFO 2013-12-17 23:04:44.107 [pool-734-thread-2] at java.lang.Thread.run(Unknown Source)
INFO | jvm 1 | 2013/12/17 23:05:09 | INFO 2013-12-17 23:05:09.144 [pool-739-thread-2] FATAL ERROR: OutOfMemory / dumping stats
INFO | jvm 1 | 2013/12/17 23:05:09 | INFO 2013-12-17 23:05:09.145 [pool-739-thread-3] FATAL ERROR: OutOfMemory / dumping stats
INFO | jvm 1 | 2013/12/17 23:05:09 | INFO 2013-12-17 23:05:09.720 [PMS Listeners Stopper] Sending BYEBYE...
INFO | jvm 1 | 2013/12/17 23:05:09 | INFO 2013-12-17 23:05:09.752 [PMS Listeners Stopper] Stopping server on host 192.168.1.128 and port 5001...
INFO | jvm 1 | 2013/12/17 23:05:09 | INFO 2013-12-17 23:05:09.763 [mencoder.exe-481] Process C:\Program Files (x86)\Universal Media Server\win32\mencoder.exe has a return code of 1! Maybe an error occurred... check the log file
INFO | jvm 1 | 2013/12/17 23:05:14 | INFO 2013-12-17 23:05:14.383 [StopPlaying Event] Stopped playing Agatha Christie's Poirot - 4x01 - The A.B.C. Murders.mkv on your PlayStation 3
STATUS | wrapper | 2013/12/17 23:05:18 | <-- Wrapper Stopped
- (13.98 KiB) Downloaded 478 times
wrapper.log
- (888.97 KiB) Downloaded 494 times
Update, I went back to version 3.2.0 and absolutely no problems now.
no errors, nothing!
everything goes as normal now.
something must have changed in the 3.3.0 that creates these errors.
*edit*
I talked too fast, while I do not get crashes, I get random studdering out of nowhere.
cpu utilization of the 4 cores never go above 70%
no errors, nothing!
*edit*
