Problem with new install
vk3laj
Post by vk3laj »
Hi All,
I've just installed and setup UMS on my MAC 10.8.5
Everything looks good, i setup my paths to the folders i want to stream/share
When scanning however it appears to be scanning everything on my mac, not the folders ive shared.
Example
12-16 09:19:32 The file /Applications/iWeb.app/Contents/Resources/Widgets/GoogleMap.iwdgt/no.lproj/mapwidget_bubble.png could not be parsed. It will be hidden
12-16 09:27:35 The file /Applications/iWeb.app/Contents/Frameworks/SFRendering.framework/Resources/Frames/Spiralbook.sfrframe/Contents/Resources/spiralboook_left.png could not be parsed. It will be hidden
12-16 09:27:47 The file /Applications/iWeb.app/Contents/Frameworks/SFRendering.framework/Versions/A/Resources/Frames/Spiralbook.sfrframe/Contents/Resources/spiralboook_left.png could not be parsed. It will be hidden
12-16 09:27:57 The file /Applications/iWeb.app/Contents/Frameworks/SFRendering.framework/Versions/Current/Resources/Frames/Spiralbook.sfrframe/Contents/Resources/spiralboook_left.png could not be parsed. It will be hidden
12-16 09:34:49 The file /Applications/iPhoto.app/Contents/Resources/Themes/Shared/Card/Colorwash/Tile_Creme.jpg could not be parsed. It will be hidden
12-16 09:36:09 The file /Applications/iPhoto.app/Contents/Resources/Themes/Assets/Shared/Frames/TravelSnapshots/P-frame-6.png could not be parsed. It will be hidden
12-16 09:36:18 The file /Applications/iPhoto.app/Contents/Resources/Themes/Assets/Shared/Frames/CremeBorder/creme-stroke-right-segment.png could not be parsed. It will be hidden
12-16 09:36:18 The file /Applications/iPhoto.app/Contents/Resources/Themes/Assets/Shared/Frames/CutoutFrame/simple-cut-blue-bttm-spacer.png could not be parsed. It will be hidden
12-16 09:37:00 The file /Applications/iPhoto.app/Contents/Resources/Themes/Assets/Mosaic/art_horse_blue.png could not be parsed. It will be hidden
Have i made a mistake?
Nothing is appearing on my devices as shared either.. :?:
Screen Shot 2013-12-16 at 9.44.32 AM.png (173.38 KiB) Viewed 6385 times
Screen Shot 2013-12-16 at 9.44.10 AM.png (108.13 KiB) Viewed 6385 times
DeFlanko
Contact:
Re: Problem with new install
Post by DeFlanko »
I think its because you have the "show iTunes Library" enabled. -- Optimus?
Optimus_prime
Post by Optimus_prime »
Uncheck the iTunes Library box and restart and see if that fixes your issue
