Install/setup Instructions for Docker Container
yoda1204
Post by yoda1204 »
I see that there is a new updated docker container that is published.
I am using Unraid version 6.8.3 with docker and the Community Application. I can download the UMS from the Docker hub. But What are the settings that I need to setup/configure. So I can get it to use my unraid share drives.
I am know at docker, so sorry for any dumb questions from me.
Re: Install/setup Instructions for Docker Container
You can see all available options in our master UMS.conf at https://raw.githubusercontent.com/Unive ... s/UMS.conf
maxq
Post by maxq »
Did you get your docker working?
Docker installs and starts ok, but I'm not able to pass the conf or other settings into the docker. Could you help me out how to docker-compose or define the docker start?
Our Docker support was a contribution from a community member who has been active on our GitHub tracker. You might be able to ask for support on here https://github.com/UniversalMediaServer ... ssues/1841
