Playback issue on Fetch TV
redavenger
Post by redavenger »
hey guys
I dont know how to submit a bug report.
I have FetchTV box which i use the media player to access universal media server.
The last version of UMS that actually worked with fetch tv was 10.7.0, all versions since they don't work.
From what I can see UMS does not seem to pick up the FetchTV config. Also when I try to browse UMS on the fetch box it takes a while...it thinks and then no folders are displayed.
Can you guys fix this, because currently I had to roll back to version 10.7.0
Re: Playback issue on Fetch TV
Could you post logs? See the section above in red or the link in my sig.
redavenger
well a bit too late for that now, i've gone back to version 10.7.0
redavenger
ok ive installed the latest UMS version 10.10.1 and the issue is still there.
i have attached a log file of a clean install.
the fetch box is ip address 192.168.0.50
so basically I can see UMS in the fetch box, however when i try to access any content is just shows blank...like nothing in it.
At the moment I've rolled back again to version 10.7
Hopefully the logs will help.
ums_dbg_2021-09-05-12-22.zip
(54.99 KiB) Downloaded 56 times
As far as I can see there is nothing coming from the Fetch box to identify itself so there is no way of UMS to figure out which conf to use.
There could be an issue with how UMS is announcing itself now that the fetch box does not understand so cant reply properly, since it is working in 10.7
I know little about the protocols but if you could you do logs of 10.7 the devs will have something to compare it to and trace down the bug.
redavenger
yes i think you are correct with the way ums is announcing itself. I have noticed with version 10.7 the fetch box can browse the folders and after a few seconds UBS can see its a "fetch box" however with the later versions its like it cant see what it is.
Anyway Ive attached logs from version 10.7 hopefully that can help.
ums_dbg_2021-09-05-18-40verision10.7.zip
(85.91 KiB) Downloaded 59 times
Could you try the latest version 10.11? There has been a fix that is probably related to this issue.
redavenger
nope still not working in 10.11...ahhh have to rollback to 10.7 :-(
redavenger
any update regarding a fix for this issue?
Michal Graham
Post by Michal Graham »
Is the issue being resolved???Is there any update to when it'll get fixed?
