add files to transcode folder
kerzer
Post by kerzer »
I have a problem, I am sharing files from my pc to my ps4 specifically concerts with 2 or 3 audio tracks. The problem is that the ps4 only recovers an audio track. After searching in google I found out that in the transcode folder you can select the other audio tracks but now my problem comes in the transcode folder only the first 7 concerts appear, the others do not appear, how can I make them appear in the transcode folder to be able to select the different audio tracks?
Re: add files to transcode folder
Hi kerzer, sorry you're having trouble with that. Can you please attach logs after reproducing the problem so we can see what is happening? Instructions are above in red
