Work and configure sopcast
hi, sorry for my english. I would like to know if it is possible, and how to configure the software for streaming Sopcast and others.
Re: Work and configure sopcast
Build a custom CONF file.
Click on the link in my signature =)
Universal Media Server Wiki!
yes, but I have not found anything that has to do with sopcast ... can you give me a link?
the problem is a web conf! the problem is that I edit and save the web conf correctly even changing existing ones with links and my ps3 always open the original link
risolto! il problema era nel modificare nel posto sbagliato con win7 bisogna modificare il file che si trova su programdata e non su program files.
Quello Grande notizia! è ok per chiudere questo thread fuori allora?
"solved! the problem was the change in the wrong place with win7 you need to edit the file that is located on programdata and not program files."
