UMS freezes
rgr
UMS freezes
Post by rgr »
My UMS freezes frequently.
Recently it has been done like this:
1. The computer is asleep.
2. I wake it up and "UMS" appears on the Playstation screen.
3. I enter folders one by one and on the target PS4 stops permanently communicating with UMS and "no files to display" appears.
4. There is nothing in the UMS logs (or I don't notice it).
5. I restart UMS, but also nothing appears and the Restart button remains gray.
6. I am trying to delete the cache - the message "The local cache could not be started, Restart ..." appears
7. In the task manager I can see two java.exe processes - one is suspended at 8% CPU usage and 671MB RAM. Until I kill him, I can't clear the cache.
By the way, deleting the cache generates such an error in the logs:
22:37:01 DEBUG Error when re-initializing after manual cache reset:
org.h2.jdbc.JdbcSQLSyntaxErrorException: Index "FILENAME_VERSION" already exists; SQL statement:
CREATE INDEX FILENAME_VERSION on FILES (FILENAME, VERSION) [42111-206]
	at org.h2.message.DbException.getJdbcSQLException(DbException.java:521)
	at org.h2.message.DbException.getJdbcSQLException(DbException.java:496)
	at org.h2.message.DbException.get(DbException.java:227)
	at org.h2.message.DbException.get(DbException.java:203)
	at org.h2.command.ddl.CreateIndex.update(CreateIndex.java:74)
	at org.h2.command.CommandContainer.update(CommandContainer.java:173)
	at org.h2.command.Command.executeUpdate(Command.java:252)
	at org.h2.jdbc.JdbcStatement.executeInternal(JdbcStatement.java:252)
	at org.h2.jdbc.JdbcStatement.execute(JdbcStatement.java:223)
	at net.pms.database.DatabaseHelper.execute(DatabaseHelper.java:357)
	at net.pms.database.MediaTableFailedLookups.createTable(MediaTableFailedLookups.java:145)
	at net.pms.database.MediaTableFailedLookups.checkTable(MediaTableFailedLookups.java:84)
	at net.pms.database.MediaDatabase.checkTables(MediaDatabase.java:105)
	at net.pms.database.MediaDatabase.reInitTablesExceptFilesStatus(MediaDatabase.java:138)
	at net.pms.database.MediaDatabase.resetCache(MediaDatabase.java:257)
	at net.pms.newgui.NavigationShareTab.lambda$initSimpleComponents$11(NavigationShareTab.java:385)
	at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
	at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
	at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
	at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
	at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
	at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:289)
	at java.awt.Component.processMouseEvent(Component.java:6539)
	at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
	at java.awt.Component.processEvent(Component.java:6304)
	at java.awt.Container.processEvent(Container.java:2239)
	at java.awt.Component.dispatchEventImpl(Component.java:4889)
	at java.awt.Container.dispatchEventImpl(Container.java:2297)
	at java.awt.Component.dispatchEvent(Component.java:4711)
	at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4904)
	at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4535)
	at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4476)
	at java.awt.Container.dispatchEventImpl(Container.java:2283)
	at java.awt.Window.dispatchEventImpl(Window.java:2746)
	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
	at java.awt.EventQueue.access$500(EventQueue.java:97)
	at java.awt.EventQueue$3.run(EventQueue.java:709)
	at java.awt.EventQueue$3.run(EventQueue.java:703)
	at java.security.AccessController.doPrivileged(Native Method)
	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)
	at java.awt.EventQueue$4.run(EventQueue.java:733)
	at java.awt.EventQueue$4.run(EventQueue.java:731)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
	at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
	at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
	at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
	at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Windows 10, UMS 10.16.0
Re: UMS freezes
One error message is not helpful. Could you post full trace logs? see the section in red above.
rgr
Re: UMS freezes
Post by rgr »
I flipped the switch to the "All" position. I'll send the log tomorrow. The last time I checked it, there was nothing in the log.
rgr
Re: UMS freezes
Post by rgr »
Log.
UMS sends "ALIVE" but is actually suspended and there is no connection to it.
Tried restarting it from the menu but when pressed the button is now permanently grayed out.
I need to kill the javaw.exe process and restart the UMS.
17:24:18 DEBUG Sending ALIVE...
17:24:49 DEBUG Sending ALIVE...
17:25:20 DEBUG Sending ALIVE...
17:25:51 DEBUG Sending ALIVE...
17:26:22 DEBUG Sending ALIVE...
17:26:22 DEBUG Recognized media renderer "PC"
17:26:53 DEBUG Sending ALIVE...
17:27:24 DEBUG Sending ALIVE...
17:27:55 DEBUG Sending ALIVE...
17:28:26 DEBUG Sending ALIVE...
17:28:57 DEBUG Sending ALIVE...
17:28:57 DEBUG Recognized media renderer "PlayStation 4"
17:28:58 DEBUG Recognized media renderer "PlayStation 4"
17:29:01 DEBUG Recognized media renderer "PlayStation 4"
17:29:01 DEBUG GlobalIdRepo: marking id 131 out of scope
17:29:01 DEBUG GlobalIdRepo: marking id 132 out of scope
17:29:01 DEBUG GlobalIdRepo: marking id 133 out of scope
17:29:01 DEBUG GlobalIdRepo: marking id 134 out of scope
17:29:02 DEBUG Recognized media renderer "PlayStation 4"
17:29:27 DEBUG Sending ALIVE...
17:29:58 DEBUG Sending ALIVE...
17:30:06 DEBUG Recognized media renderer "PlayStation 4"
17:30:29 DEBUG Sending ALIVE...
17:31:00 DEBUG Sending ALIVE...
17:31:31 DEBUG Sending ALIVE...
17:32:02 DEBUG Sending ALIVE...
17:32:33 DEBUG Sending ALIVE...
17:33:04 DEBUG Sending ALIVE...
17:33:35 DEBUG Sending ALIVE...
17:34:06 DEBUG Sending ALIVE...
17:34:37 DEBUG Sending ALIVE...
17:35:08 DEBUG Sending ALIVE...
17:35:39 DEBUG Sending ALIVE...
17:36:10 DEBUG Sending ALIVE...
17:36:41 DEBUG Sending ALIVE...
17:37:12 DEBUG Sending ALIVE...
17:37:43 DEBUG Sending ALIVE...
17:38:14 DEBUG Sending ALIVE...
17:38:45 DEBUG Sending ALIVE...
17:39:16 DEBUG Sending ALIVE...
17:39:47 DEBUG Sending ALIVE...
17:40:18 DEBUG Sending ALIVE...
17:40:49 DEBUG Sending ALIVE...
17:41:19 DEBUG Sending ALIVE...
17:41:50 DEBUG Sending ALIVE...
17:42:21 DEBUG Sending ALIVE...
17:42:52 DEBUG Sending ALIVE...
17:43:22 DEBUG Checking dbgpack property in UMS.conf
17:43:22 DEBUG adding C:\Program Files (x86)\Universal Media Server\renderers\Microsoft-WindowsMediaPlayer.conf
17:43:22 DEBUG adding C:\Program Files (x86)\Universal Media Server\renderers\Sony-PlayStation4.conf
17:43:22 DEBUG adding C:\ProgramData\UMS\WEB.conf
17:43:22 DEBUG adding C:\ProgramData\UMS\UMS.conf
17:43:22 DEBUG adding C:\ProgramData\UMS\debug.log.prev
17:43:23 DEBUG Sending ALIVE...
17:43:28 DEBUG Default logfile folder set to: C:\Users\Właściciel\Desktop\UMS-log
17:43:32 DEBUG Packing C:\Program Files (x86)\Universal Media Server\renderers\Microsoft-WindowsMediaPlayer.conf
17:43:32 DEBUG Packing C:\Program Files (x86)\Universal Media Server\renderers\Sony-PlayStation4.conf
17:43:32 DEBUG Packing C:\ProgramData\UMS\WEB.conf
17:43:32 DEBUG Packing C:\ProgramData\UMS\UMS.conf
17:43:32 DEBUG Packing C:\ProgramData\UMS\debug.log
17:43:39 DEBUG singleton task restart started
17:43:39 DEBUG task started
17:43:39 DEBUG Sending BYEBYE...
17:43:39 DEBUG Sending ALIVE...
17:43:39 DEBUG Stopping UPNP Services...
17:43:40 INFO  Stopping server on host 192.168.0.2 and port 5001...
17:43:40 INFO  Confirm allChannels is empty: DefaultChannelGroup(name: HTTPServer, size: 0)
17:44:10 DEBUG Sending ALIVE...
17:44:41 DEBUG Sending ALIVE...
17:44:45 DEBUG Checking dbgpack property in UMS.conf
17:44:45 DEBUG adding C:\Program Files (x86)\Universal Media Server\renderers\Microsoft-WindowsMediaPlayer.conf
17:44:45 DEBUG adding C:\Program Files (x86)\Universal Media Server\renderers\Sony-PlayStation4.conf
17:44:45 DEBUG adding C:\ProgramData\UMS\WEB.conf
17:44:45 DEBUG adding C:\ProgramData\UMS\UMS.conf
17:44:45 DEBUG adding C:\ProgramData\UMS\debug.log.prev
17:44:56 DEBUG Packing C:\Program Files (x86)\Universal Media Server\renderers\Microsoft-WindowsMediaPlayer.conf
17:44:56 DEBUG Packing C:\Program Files (x86)\Universal Media Server\renderers\Sony-PlayStation4.conf
17:44:56 DEBUG Packing C:\ProgramData\UMS\WEB.conf
17:44:56 DEBUG Packing C:\ProgramData\UMS\UMS.conf
17:44:56 DEBUG Packing C:\ProgramData\UMS\debug.log
17:45:12 DEBUG Sending ALIVE...
17:45:43 DEBUG Sending ALIVE...
Re: UMS freezes
There was no information there.
Could you post full trace logs? see the section in red above on how to create them and attach them to your post.
