LG TV (webOS) transcode only audio?
Hey all,
My new LG tv can't handle DTS audio. I'm having trouble figuring out the settings so that a 4K mkv will play without transcoding the video, but with transcoding only the audio from DTS to a format the LG can handle.
My current LG-WebOS.conf is attached.
When I attempt to play the file from the main directory, video and audio play but it is definitely transcoding the video and looks very lossy. When I play the same file from within the Transcode folder and select 'No Transcoding' the video looks fantastic, but no audio plays.
What am I missing in the config to have it leave the video as-is, but transcode the audio to AC-3, or something similar?
the first attempt at playing is below:
and MediaInfo:
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.util.SubtitleUtils Searching for external subtitles for Interstellar.2014.UHD.BluRay.2160p.DTS-HD.MA.5.1.HEVC.REMUX-FraMeSToR.mkv
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.database.MediaTableThumbnails Searching for thumbnail in THUMBNAILS with "SELECT ID FROM THUMBNAILS WHERE MD5 = 'c972451a2c51dced2e038c2dc5562331' LIMIT 1" before update
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.database.MediaTableThumbnails Found existing thumbnail with ID 16 in THUMBNAILS, setting the THUMBID in the FILES table
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.database.MediaTableFiles THUMBID updated to 16 for F:\Movies\Interstellar 4K\Interstellar.2014.UHD.BluRay.2160p.DTS-HD.MA.5.1.HEVC.REMUX-FraMeSToR.mkv
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.dlna.DLNAResource Adding new child "Interstellar.2014.UHD.BluRay.2160p.DTS-HD.MA.5.1.HEVC.REMUX-FraMeSToR.mkv" with class "RealFile"
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.dlna.DLNAResource Looking for an audio track with language "eng" for "Interstellar.2014.UHD.BluRay.2160p.DTS-HD.MA.5.1.HEVC.REMUX-FraMeSToR.mkv"
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.dlna.DLNAResource Matched audio track: Id: 0, Language Code: eng, Audio Track Title From Metadata: DTS-HD MA 5.1, Audio Codec: DTS HD, Bitrate: 3686198, Bits per Sample: 24, Channels: 6, Sample Frequency: 48000 Hz
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.dlna.DLNAResource No external subtitles candidates were found to force for "Interstellar.2014.UHD.BluRay.2160p.DTS-HD.MA.5.1.HEVC.REMUX-FraMeSToR.mkv"
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.dlna.DLNAResource Searching for a match for audio language "eng" with audio "eng" and subtitles "off" for "Interstellar.2014.UHD.BluRay.2160p.DTS-HD.MA.5.1.HEVC.REMUX-FraMeSToR.mkv"
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.dlna.DLNAResource Not looking for non-forced subtitles since they are "off" for audio language "eng"
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.dlna.DLNAResource Found no matching subtitle for "Interstellar.2014.UHD.BluRay.2160p.DTS-HD.MA.5.1.HEVC.REMUX-FraMeSToR.mkv"
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.formats.FormatFactory Getting player for resource "Interstellar.2014.UHD.BluRay.2160p.DTS-HD.MA.5.1.HEVC.REMUX-FraMeSToR.mkv"
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.formats.FormatFactory Returning compatible player "FFmpeg Video"
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.configuration.FormatConfiguration Format "mkv" failed to match supported line f:wmv|asf v:wmv|vc1 a:wma m:video/x-ms-wmv
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.configuration.FormatConfiguration Format "mkv" failed to match supported line f:avi v:h264|mp4|xvid|mjpeg a:mp3|ac3|lcpm|adpcm m:video/avi
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.configuration.FormatConfiguration Format "mkv" failed to match supported line f:mp4|m4v|mov v:h264|h265|mp4 a:mp3|ac3|eac3|aac-lc|he-aac m:video/mp4
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.configuration.FormatConfiguration Audio codec "dtshd" failed to match support line f:mkv v:h264|h265|mp4|mpeg2|vp8|vp9 a:mp3|ac3|eac3|aac-lc|he-aac|adpcm m:video/x-matroska vbd:8|10
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.configuration.FormatConfiguration Format "mkv" failed to match supported line f:mpegts v:h264|h265|mpeg2 a:mp3|ac3|eac3|aac-lc|he-aac|adpcm m:video/mpeg
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.configuration.FormatConfiguration Format "mkv" failed to match supported line f:mpegps v:h264|h265|mpeg2 a:mp3|ac3|eac3|aac-lc|he-aac|adpcm m:video/mpeg
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.configuration.FormatConfiguration Format "mkv" failed to match supported line f:mpg|mpeg|dat v:mpeg1|mpeg2 a:mp3 m:video/mpeg
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.configuration.FormatConfiguration Format "mkv" failed to match supported line f:vob v:mpeg1|mpeg2 a:ac3|mpa|mp2|lpcm m:video/mpeg
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.configuration.FormatConfiguration Format "mkv" failed to match supported line f:3gp|3g2 v:h264|mp4 a:aac-lc|he-aac|amr m:video/3gpp
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.configuration.FormatConfiguration Format "mkv" failed to match supported line f:rm|rmvb a:aac-lc|he-aac m:application/vnd.rn-realmedia-vbr
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.configuration.FormatConfiguration Format "mkv" failed to match supported line f:mp3 m:audio/mpeg
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.configuration.FormatConfiguration Format "mkv" failed to match supported line f:wav m:audio/L16
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.configuration.FormatConfiguration Format "mkv" failed to match supported line f:ogg m:audio/ogg
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.configuration.FormatConfiguration Format "mkv" failed to match supported line f:wma m:audio/x-ms-wma
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.configuration.FormatConfiguration Format "mkv" failed to match supported line f:flac m:audio/x-flac
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.configuration.FormatConfiguration Format "mkv" failed to match supported line f:jpg|jpg|jpe w:15360 h:8640 m:image/jpeg
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.configuration.FormatConfiguration Format "mkv" failed to match supported line f:png w:5760 h:5760 m:image/png
TRACE 2022-05-11 17:33:01.585 [HTTPv2 Request Worker 4] net.pms.configuration.FormatConfiguration Format "mkv" failed to match supported line f:bmp w:1920 h:1080 m:image/bmp
General
Unique ID : 332398145331619288711835413871089210445 (0xFA118DDD1F1328DDA41ECD5C3070D44D)
Complete name : F:\Movies\Interstellar 4K\Interstellar.2014.UHD.BluRay.2160p.DTS-HD.MA.5.1.HEVC.REMUX-FraMeSToR.mkv
Format : Matroska
Format version : Version 4
File size : 65.7 GiB
Duration : 2 h 49 min
Overall bit rate mode : Variable
Overall bit rate : 55.7 Mb/s
Movie name : Interstellar (2014) 4K
Encoded date : UTC 2018-01-15 16:57:30
Writing application : mkvmerge v19.0.0 ('Brave Captain') 64-bit
Writing library : libebml v1.3.5 + libmatroska v1.4.8
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main [email protected]@High
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 51.8 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.261
Stream size : 61.2 GiB (93%)
Writing library : ATEME Titan File 3.8.3 (4.8.3.0)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 1242 cd/m2
Maximum Frame-Average Light Level : 436 cd/m2
Audio
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate mode : Variable
Bit rate : 3 686 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 4.35 GiB (7%)
Title : DTS-HD MA 5.1
Language : English
Default : Yes
Forced : No
Text #1
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 2 h 42 min
Bit rate : 34.4 kb/s
Count of elements : 3946
Stream size : 40.0 MiB (0%)
Title : English
Language : English
Default : No
Forced : No
Text #2
Format : PGS
Bit rate : 37.2 kb/s
Count of elements : 4192
Stream size : 43.3 MiB (0%)
Title : English (SDH)
Language : English
Default : No
Forced : No
Text #3
Format : PGS
Bit rate : 30.0 kb/s
Count of elements : 4196
Stream size : 34.9 MiB (0%)
Title : French
Language : French
Default : No
Forced : No
Text #4
Format : PGS
Duration : 2 h 47 min
Bit rate : 34.6 kb/s
Count of elements : 3982
Stream size : 41.5 MiB (0%)
Title : Spanish (Latin American)
Language : Spanish
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 1
00:09:35.492 : en:Chapter 2
00:17:12.323 : en:Chapter 3
00:25:00.749 : en:Chapter 4
00:35:45.393 : en:Chapter 5
00:42:16.868 : en:Chapter 6
00:50:19.892 : en:Chapter 7
00:54:48.076 : en:Chapter 8
00:58:59.703 : en:Chapter 9
01:06:15.013 : en:Chapter 10
01:17:28.185 : en:Chapter 11
01:25:32.002 : en:Chapter 12
01:34:32.000 : en:Chapter 13
01:46:14.702 : en:Chapter 14
01:55:34.553 : en:Chapter 15
02:02:14.369 : en:Chapter 16
02:12:56.844 : en:Chapter 17
02:20:53.820 : en:Chapter 18
02:35:12.094 : en:Chapter 19
02:43:59.830 : en:Chapter 20
LG-WebOS.conf
- (3.79 KiB) Downloaded 843 times
- ums_dbg_2022-05-11-17-38.zip
- (293.57 KiB) Downloaded 725 times
Re: LG TV (webOS) transcode only audio?
I never got DTS files working with my LG OLED. Even after commenting out DTS of the configuration, which should force UMS to transcode DTS to AC3 didn't work. I fumbled around with that to the point that I just went over to converting DTS to AC3 with an ffmpeg command line prompt, that saves me the headache of trying to get it transcoded on the fly.
If anyone has any other suggestion that works, I'll be glad to hear.
AC3 transcode from DTS works for me (C1), check the support thread for my config.
Thanks - my issue isn't that I can't get DTS to transcode to AC3, that is working fine for me -- my issue is that I only want audio transcoding, with no video transcoding. My LG keeps transcoding both audio and video resulting in a very lossy video quality.
I did try your config file here (viewtopic.php?f=9&t=15142&p=45640#p45640) but same results for me - audio is transcoding OK from DTS to AC3, but video is also transcoding from source HEVC H265 to H264 and looking very lossy.
I'm trying to force audio to transcode without touching the video. Is this possible?
No problem, but why is HEVC being transcoded? For me it streams, and audio is transcoding if needed. My current config is: I just delete all LG* renderers in the renderers dir and add only as per attachment.
LG-OLED.conf
- (2.31 KiB) Downloaded 670 times
Yep, that's the question indeed. I don't know why it keeps insisting on transcoding the HEVC video when the LG TV supports it fine. (Playing the video in the Transcode folder with no transcoding works perfectly for video, but doesn't play the audio due to the DTS format).
I tried your config again and it's still transcoding both audio and video.
I was just testing it. I have a sound bar with DTS support, even then it doesn't work and DTS is not possible. Same situation with direct casting the file (without UMS). DTS possible only on PS5 with BR discs.
When I choose "No Transcoding" the video is fine, but no DTS sound.
When I choose FFMPEG / DTSHD, it transcodes audio + video.
So I guess I have the same problem.
Ha, I appreciate this follow up. Glad I'm not going nuts.zer69 wrote: ↑Sat Sep 03, 2022 7:25 am I was just testing it. I have a sound bar with DTS support, even then it doesn't work and DTS is not possible. Same situation with direct casting the file (without UMS). DTS possible only on PS5 with BR discs.
So I guess I have the same problem.![]()
I did find a custom FFMpeg setting that just copies the video, no transcoding, and transcodes just the audio. When I use that the audio works, and the video looks fantastic and is HEVC... for the first 20 seconds or so, then the video scrambles 3/4s of the screen leaving only the top left 1/4 playing visible video. So, I guess I have a new problem now...
If your TV supports passing though the DTS to your soundbar with ARC then you can edit your conf to add dts or dtshd in the supported formats section so UMS will not transcode it automatically.
Yes, the problem is that LG dropped DTS support altogether since 2020 I think. It won't even allow pass-through.
