UMS fails to build
alexelcaza
UMS fails to build
Post by alexelcaza »
used this https://github.com/UniversalMediaServer ... -build-UMS
followed the full instructions for windows yet it always fails with the same error
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.10.1:compile (default-compile) on project ums: Fatal error compiling: invalid target release: 17 -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.10.1:compile (default-compile) on project ums: Fatal error compiling
Re: UMS fails to build
I think those instructions need updating as they moved to a newer version of Java JDK for V11 IIRC.
I did manage to setup my system to build UMS a couple of years ago but have not tried since then so I don't remember how I did it or what has changed.
It might be quicker to get a response on GitHub from the devs as they are more active on there.
alexelcaza
thank you so much! it builds fine with JDK 18
