UMS 3.3.0 & jumpy 0.3.0/Philips TV Stop Play
totoloto
Post by totoloto »
DEBUG FILE
(27.64 KiB) Downloaded 294 times
ums_dbg_toto.zip
My Konfig
(18.84 KiB) Downloaded 289 times
My Philips TV PFL427008
Operating System windows 7 ultimate
UMS is instaled 3.3.0, 0.3.0 Jumpy, XBMC, Plug In Heelenic TV
It all works
The problem is that the playback runs only 20 seconds, then stops the TV
Can it be due to a setting and if so which ones?
Does anyone have a tip?
I am not a computer expert :-)
Thank you
19.0.12014 it looks as if the tv will stream the record and not play!
totoloto
Re: UMS 3.3.0 & jumpy 0.3.0/Philips TV Stop Play
Post by totoloto »
NEW DEBUG FILE!
infidel
Post by infidel »
totoloto wrote:Plug In Hellenic TV... playback runs only 20 seconds, then stops
Hi, I'm working on a full solution, but for now try this as a temporary workaround:
  • open jumpy.conf by pressing the button in the jumpy gui.
  • add this line to the file:
    resolve_at_playback=false
  • save and restart UMS.
totoloto
Post by totoloto »
hello infidel, that was a good tip!
It works.
Thank you.
You are invited to one or two of ouzo :)
