I am getting error message Automatic maximum bitrate calculation failed with: Cannot invoke "java.util.List.iterator()"
go_nuts
Post by go_nuts »
I am working on a playstation3 and I am getting an error message
Automatic maximum bitrate calculation failed with: Cannot invoke "java.util.List.iterator()" because "ls" is null
This seems to be coming from that ping was not automatically installed on my machine.. (which is something that you might expect but I assume that Ubuntu is optimizing for cloud services where OS are commodities )
Possible Cause
Seems like the issue likely got tripped up on in SpeedStats#doPing ..
Resolution
I resolved with sudo apt-get install iputils-ping working as expected..
I assume that you might want to protect against this in some way like making its at least an empty list since this is something that can happen (which I would have never thought that it would have been) . Or at least give a better error message when the one that I go.
Re: I am getting error message Automatic maximum bitrate calculation failed with: Cannot invoke "java.util.List.iterator
I'll make an issue on GitHub so the Devs can add this check and maybe install ping if it is not available. I think they assumed that this was a basic function on all OSs, I had no Idea it was not.
RaceRachael
Post by RaceRachael »
I have same problem..
