New renderer for Philips 75pus8108
Hi everyone and merry chistmas to all of u
I'm using two Philips TV : one 32 inches which is working fine with UMS 13.8 with this ums renderer file attached
But it's not working on my new 75pus8108... Is there another renderer file to use ? Which configuration should I change ?
Synology is working fine with DLNA with this 75 inches TV
If someone has an idea ?
Thanks in advance
Alexis
Thanks in advance
Alexis
Philips-PFL.conf
- (9.78 KiB) Downloaded 528 times
Re: New renderer for Philips 75pus8108
That conf has been altered to make UMS ignore the formats being used and just stream everything. You should not use this when all supported formats have been defined otherwise you are likely to come across unsupported videos that will not play anymore as UMS will not know to transcode them.
The way the UserAgentSearch search has been changed is probably making both TVs use the same conf.
If both your TVs are using this conf then it is likely that they have different format support so videos that work on one will not work on the other.
There is a conf for the PUS series that should work but is not being used because of that change.
Restore this original PFL conf and see it it works as intended.
To be of any more help I will need to see logs of what each TV is using. See the link in my sig.
Philips-PFL.conf
- (9.01 KiB) Downloaded 600 times
