SETUP NETWORK / Security
Rebelmonk
Post by Rebelmonk »
Hi - I just installed UMS - all working ok ...except...I'm a little unsure of what UMS is allowing access to and how to limit / security protect my comp.
I checked out if UMS was working on the digital radio I wan to stream my music too and lo and behold I could see my entire Home drive on the radio...So I pretty quickly shut it down.
I looked in the settings to try and limit the file sharing to just my itunes folder but I couldn't work out how to do that...any advice would be most helpful.
Also can you tell me where UMS installs to it does appear in my applications folder - so was a little concerned about removing it should I not be able to figure out above.
RM
