inconsistent scan of renderers
stephenbbb
Post by stephenbbb »
I have UMS 13.5 on
Kernel: 6.8.0-52-generic x86_64 bits: 64 compiler: N/A Desktop: Xfce 4.18.1 tk: Gtk 3.24.33
info: xfce4-panel wm: xfwm 4.18.0 vt: 7 dm: LightDM 1.30.0 Distro: Linux Mint 21.3 Virginia
base: Ubuntu 22.04 jammy
I used to be able to see the sever on my Roku TV in the Media Player channel and stream video. Now the scanner does not see the Roku.
I can post any of the output in the terminal that is requested. The output is long.
I installed a new UMS on another laptop and it also does not see the Roku and Roku does not see the server.
I know the older version used to work, is it possible the Linux kernel (after many updates) is now the problem??
boss
Re: inconsistent scan of renderers
Post by boss »
I am running Linux Kernel 6.12.21
Last 2 before that ver Kernel 6.12.16 and 6.6.74
Those 3 kernels ran fine with UMS.
UMS version: 14.11.0 current
Only V13 UMS I had running was: 13.9.0 (worked fine)
I would suggest updating UMS to V14.11.0
There could be other reasons why UMS is not showing on the Roku but will need to see logs to know why. See the section in red above.
