Completely uninstall UMS
Hi all!
I installed UMS yesterday and all was well. Than i installed some plugins and some Java error appeared every time i was starting UMS keeping it from working. So i trashed the application from applications folder and installed again. I noticed that the installer didn't ask me the same config questions. Now UMS doesn't find renders. I think a complete uninstall should do it but i dont know how to do it. Can somebody help?
OSX Maveriks on 2007 Imac.
Re: Completely uninstall UMS
Ok, i found the UMS folder on Application Support, deleted it and managed to make a clean install.
UMS can't still find my TV (LG 47LA667). Here is the Log (good thing the app has a log tab):
03-19 22:12:01 Starting Universal Media Server 3.4.2
03-19 22:12:01 Based on PS3 Media Server by shagrath, copyright 2008-2014
03-19 22:12:01 http://www.universalmediaserver.com
03-19 22:12:01
03-19 22:12:01 Build: 215ce3161 (2014-02-24)
03-19 22:12:01 Java: Java HotSpot(TM) 64-Bit Server VM 1.6.0_65 64-bit by Apple Inc.
03-19 22:12:01 OS: Mac OS X 64-bit 10.9.2
03-19 22:12:01 Encoding: UTF-8
03-19 22:12:01 Memory: 763 MB
03-19 22:12:01 Language: en
03-19 22:12:01
03-19 22:12:01 Working directory: /Applications/Universal Media Server.app/Contents/Resources/Java
03-19 22:12:01 Temp directory: /var/folders/_w/vdvh0jwd025fjpznzh7rkks00000gn/T/universalmediaserver
03-19 22:12:01 Logging config file: /Applications/Universal Media Server.app/Contents/Resources/Java/logback.xml
03-19 22:12:01 debug.log: /Users/joaobucho/Library/Application Support/UMS/debug.log
03-19 22:12:01
03-19 22:12:01 Profile directory: /Users/joaobucho/Library/Application Support/UMS
03-19 22:12:01 Profile directory permissions: rw
03-19 22:12:01 Profile path: /Users/joaobucho/Library/Application Support/UMS/UMS.conf
03-19 22:12:01 Profile permissions: rw
03-19 22:12:01 Profile name: MENINO.local
03-19 22:12:01
03-19 22:12:01 Web conf path: /Users/joaobucho/Library/Application Support/UMS/WEB.conf
03-19 22:12:01 Web conf permissions: file not found
03-19 22:12:01
03-19 22:12:01 Loading MediaInfo library
03-19 22:12:01 Loaded MediaInfoLib - v0.7.58
03-19 22:12:01 Loading renderer configurations from /Applications/Universal Media Server.app/Contents/Resources/Java/renderers
03-19 22:12:01 Loaded configuration for renderer: AirPlayer
03-19 22:12:01 Loaded configuration for renderer: Android
03-19 22:12:01 Loaded configuration for renderer: KalemSoft Media Player
03-19 22:12:01 Loaded configuration for renderer: Sony Bravia 4500
03-19 22:12:01 Loaded configuration for renderer: Sony Bravia 5500
03-19 22:12:01 Loaded configuration for renderer: Sony Bravia EX
03-19 22:12:01 Loaded configuration for renderer: Sony Bravia EX620
03-19 22:12:01 Loaded configuration for renderer: Sony Bravia HX
03-19 22:12:01 Loaded configuration for renderer: Sony Bravia W6/W8/W9
03-19 22:12:01 Loaded configuration for renderer: D-Link DSM-510
03-19 22:12:01 Loaded configuration for renderer: DirecTV HR
03-19 22:12:01 Loaded configuration for renderer: Freebox HD
03-19 22:12:01 Loaded configuration for renderer: Freecom MusicPal
03-19 22:12:02 Loaded configuration for renderer: Pioneer Kuro
03-19 22:12:02 Loaded configuration for renderer: LG 42LA644V
03-19 22:12:02 Loaded configuration for renderer: LG Smart TV Upgrader
03-19 22:12:02 Loaded configuration for renderer: Nokia N900
03-19 22:12:02 Loaded configuration for renderer: Netgear NeoTV
03-19 22:12:02 Loaded configuration for renderer: OPPO BDP-83
03-19 22:12:02 Loaded configuration for renderer: OPPO BDP-93
03-19 22:12:02 Loaded configuration for renderer: Onkyo TX-NR717
03-19 22:12:02 Loaded configuration for renderer: PlayStation 3
03-19 22:12:02 Loaded configuration for renderer: Panasonic TV
03-19 22:12:02 Loaded configuration for renderer: Panasonic TX-L32V10E
03-19 22:12:02 Loaded configuration for renderer: Philips Aurea
03-19 22:12:02 Loaded configuration for renderer: Philips TV
03-19 22:12:02 Loaded configuration for renderer: Popcorn Hour
03-19 22:12:02 Loaded configuration for renderer: Realtek
03-19 22:12:02 Loaded configuration for renderer: Sony SMP-N100
03-19 22:12:02 Loaded configuration for renderer: Samsung SMT-G7400
03-19 22:12:02 Loaded configuration for renderer: Samsung D7000
03-19 22:12:02 Loaded configuration for renderer: Samsung AllShare
03-19 22:12:02 Loaded configuration for renderer: Samsung Mobile
03-19 22:12:02 Loaded configuration for renderer: Samsung WiseLink
03-19 22:12:02 Loaded configuration for renderer: Sharp Aquos
03-19 22:12:02 Loaded configuration for renderer: Showtime 3
03-19 22:12:02 Loaded configuration for renderer: Showtime 4
03-19 22:12:02 Loaded configuration for renderer: Sony Blu-ray
03-19 22:12:02 Loaded configuration for renderer: Sony Home Theatre System
03-19 22:12:02 Loaded configuration for renderer: Sony STR-DA5800ES
03-19 22:12:02 Loaded configuration for renderer: Streamium
03-19 22:12:02 Loaded configuration for renderer: Telstra T-Box
03-19 22:12:02 Loaded configuration for renderer: VideoWeb TV
03-19 22:12:02 Loaded configuration for renderer: Vizio Smart TV
03-19 22:12:02 Loaded configuration for renderer: WD TV Live
03-19 22:12:02 Loaded configuration for renderer: WMP
03-19 22:12:02 Loaded configuration for renderer: XBMC
03-19 22:12:02 Loaded configuration for renderer: Xbox 360
03-19 22:12:02 Loaded configuration for renderer: Yamaha RX-A1010
03-19 22:12:02 Loaded configuration for renderer: Yamaha RX-V3900
03-19 22:12:02 Loaded configuration for renderer: Yamaha RX-V671
03-19 22:12:02 Loaded configuration for renderer: iPad / iPhone
03-19 22:12:02 Checking the fontconfig cache, this can take two minutes or so.
03-19 22:12:02 Searching for plugins in /Applications/Universal Media Server.app/Contents/Resources/Java/plugins
03-19 22:12:02 No plugins found
03-19 22:12:02 Registering transcoding engine: FFmpeg Audio
03-19 22:12:02 Registering transcoding engine: MEncoder
03-19 22:12:02 Registering transcoding engine: VLC
03-19 22:12:02 Registering transcoding engine: FFmpeg Web Video
03-19 22:12:02 Registering transcoding engine: MEncoder Web
03-19 22:12:02 Registering transcoding engine: VLC Web Video
03-19 22:12:02 Registering transcoding engine: tsMuxeR
03-19 22:12:02 Registering transcoding engine: Audio High Fidelity
03-19 22:12:02 Registering transcoding engine: VLC Web Audio (Legacy)
03-19 22:12:02 Registering transcoding engine: VLC Web Video (Legacy)
03-19 22:12:02 Registering transcoding engine: dcraw Thumbnailer
03-19 22:12:02 Using address /169.254.7.133 found on network interface: name:fw0 (fw0)
03-19 22:12:02 Created socket: /169.254.7.133:5001
03-19 22:12:03 Using the following UUID configured in UMS.conf: c54dbce9-8d85-48fb-8dfb-90c8e1ff22e0
03-19 22:12:03 The server is now available for renderers to find
03-19 22:12:47 No IP filter specified, access granted to /192.168.1.48
My TV is on 192.168.1.48 IP. The Log says "access granted" but still "no renders were found" and the TV cant find UMS as a DLNA.
Please help, I really like UMS and i don't want to use other DLNA.
03-19 22:12:01
03-19 22:12:01
03-19 22:12:01
03-19 22:12:01
03-19 22:12:01
- Optimus_prime
Your network address is on /169.254.7.133 but your renderer is on a different network 192.168.1.48. Maybe check you network settings.
Also a new version is out.
Nice! I didnt noticed they were on diferent networks. Thanks a lot!
