OSX 10.9.2 Mavericks with java 8. Asian characters issue
darkerthanblack
Post by darkerthanblack »
Hi!
Recently, I have updated my java to Oracle java 8 and unversal media server 3.4.2 to 3.5(Java 7 compile version).
Then, Videos with Asian characters titles can not be streamed.
If I change the titles to English only ones, it is streamed correctly.
03-24 22:29:01 Starting Universal Media Server 3.5.0
03-24 22:29:01 Based on PS3 Media Server by shagrath, copyright 2008-2014
03-24 22:29:01 http://www.universalmediaserver.com
03-24 22:29:01
03-24 22:29:01 Build: bf8c8fabd (2014-03-19)
03-24 22:29:01 Java: Java HotSpot(TM) 64-Bit Server VM 1.8.0 64-bit by Oracle Corporation
03-24 22:29:01 OS: Mac OS X 64-bit 10.9.2
03-24 22:29:01 Encoding: UTF-8
03-24 22:29:01 Memory: 683 MB
03-24 22:29:01 Language: ko
03-24 22:29:18 The file /Volumes/Shredis/temp/[ 홈랜드(Homeland) - 시즌1 - 01화~12화(완) ]/Homeland.S01E02.HDTV.XviD-FQM.avi could not be parsed. It will be hidden
03-24 22:29:18 The file /Volumes/Shredis/temp/[ 홈랜드(Homeland) - 시즌1 - 01화~12화(완) ]/Homeland.S01E03.HDTV.XviD-ASAP.avi could not be parsed. It will be hidden
03-24 22:29:18 The file /Volumes/Shredis/temp/[ 홈랜드(Homeland) - 시즌1 - 01화~12화(완) ]/Homeland.S01E04.HDTV.XviD-ASAP.avi could not be parsed. It will be hidden
03-24 22:29:19 The file /Volumes/Shredis/temp/[ 홈랜드(Homeland) - 시즌1 - 01화~12화(완) ]/Homeland.S01E05.HDTV.XviD-LOL.avi could not be parsed. It will be hidden
03-24 22:29:19 The file /Volumes/Shredis/temp/[ 홈랜드(Homeland) - 시즌1 - 01화~12화(완) ]/Homeland.S01E06.HDTV.XviD-LOL.avi could not be parsed. It will be hidden
03-24 22:29:19 The file /Volumes/Shredis/temp/[ 홈랜드(Homeland) - 시즌1 - 01화~12화(완) ]/Homeland.S01E07.HDTV.XviD-FEVER.avi could not be parsed. It will be hidden
03-24 22:29:19 The file /Volumes/Shredis/temp/[ 홈랜드(Homeland) - 시즌1 - 01화~12화(완) ]/Homeland.S01E08.HDTV.XviD-ASAP.avi could not be parsed. It will be hidden
03-24 22:29:19 The file /Volumes/Shredis/temp/[ 홈랜드(Homeland) - 시즌1 - 01화~12화(완) ]/Homeland.S01E09.HDTV.XviD-LOL.avi could not be parsed. It will be hidden
03-24 22:29:19 The file /Volumes/Shredis/temp/[ 홈랜드(Homeland) - 시즌1 - 01화~12화(완) ]/Homeland.S01E10.HDTV.XviD-ASAP.avi could not be parsed. It will be hidden
03-24 22:29:19 The file /Volumes/Shredis/temp/[ 홈랜드(Homeland) - 시즌1 - 01화~12화(완) ]/Homeland.S01E11.HDTV.XviD-ASAP.avi could not be parsed. It will be hidden
03-24 22:29:19 The file /Volumes/Shredis/temp/[ 홈랜드(Homeland) - 시즌1 - 01화~12화(완) ]/Homeland.S01E12.HDTV.XviD-LOL.avi could not be parsed. It will be hidden
Thanks.
Optimus_prime
Re: OSX 10.9.2 Mavericks with java 8. Asian characters issue
Post by Optimus_prime »
Was it working correctly in previous versions?
darkerthanblack
Optimus_prime wrote:Was it working correctly in previous versions?
Yes. It was working.
popoguy
Post by popoguy »
yes, i have test on Ps3 server and universal media server, my status is as same as you. It CANNOT display the unicode (utf-8 or utf-16) in srt format.
Anyone can correctly setting in using utf-8 unicode in asian characters? pls provide the setting to us.
Optimus_prime
As we haven't moved over to Java 8 as yet, it may remain untested. I only provided Java 8 versions of UMS for testing, but i will have a look into your issue and if i can provide something i will
darkerthanblack
Sorry. I thought that the issue was solved on 4.60 but it was java 6 compile version not java 8.
I have tested newly UMS 4.60 java 8 and the problem is there.
Thanks.
Optimus_prime
Ok well i will have a look into it.
meetgood
Post by meetgood »
Anybody solve this problem?
Optimus_prime
could you provide a full debug log in accordance with the Problem reporting guidelines at the top of the post and i'll have someone look into it
meetgood
Post by meetgood »
attached
02-04 22:08:13  Starting Universal Media Server 5.0.0
02-04 22:08:13  Based on PS3 Media Server by shagrath, copyright 2008-2014
02-04 22:08:13  http://www.universalmediaserver.com
02-04 22:08:13
02-04 22:08:13  Build: afee48bdd (2015-01-24)
02-04 22:08:13  Java: Java HotSpot(TM) 64-Bit Server VM 1.8.0_31 64-bit by Oracle Corporation
02-04 22:08:13  OS: Mac OS X 64-bit 10.9.5
02-04 22:08:13  Encoding: UTF-8
02-04 22:08:13  Memory: 683 MB
02-04 22:08:13  Language: en
02-04 22:08:13
02-04 22:08:13  Working directory: /Applications/Universal Media Server.app/Contents/Resources
02-04 22:08:13  Temp directory: /var/folders/62/t6s1mj1x6mjf3b79zjk2d4gw0000gn/T/universalmediaserver
02-04 22:08:13  Logging config file: /Applications/Universal Media Server.app/Contents/Resources/logback.xml
02-04 22:08:13  debug.log: /Users/cosmo/Library/Application Support/UMS/debug.log
02-04 22:08:13
02-04 22:08:13  Profile directory: /Users/cosmo/Library/Application Support/UMS
02-04 22:08:13  Profile directory permissions: rw
02-04 22:08:13  Profile path: /Users/cosmo/Library/Application Support/UMS/UMS.conf
02-04 22:08:13  Profile permissions: rw
02-04 22:08:13  Profile name: macbook-air
02-04 22:08:13
02-04 22:08:13  Web conf path: /Users/cosmo/Library/Application Support/UMS/WEB.conf
02-04 22:08:13  Web conf permissions: file not found
02-04 22:08:13
02-04 22:08:13  Loading renderer names from /Applications/Universal Media Server.app/Contents/Resources/renderers
02-04 22:08:13  Loading MediaInfo library
02-04 22:08:13  Loaded MediaInfoLib - v0.7.58
02-04 22:08:13  Checking shared folder: /Users/cosmo/Documents
02-04 22:08:13  Loading renderer configurations from /Applications/Universal Media Server.app/Contents/Resources/renderers
02-04 22:08:13  Enabled 105 configurations, listed in order of loading priority:
02-04 22:08:13  :   Panasonic AS600
02-04 22:08:13  :   Panasonic AS650
02-04 22:08:13  :   Panasonic BDT360
02-04 22:08:13  :   Panasonic ET60
02-04 22:08:13  :   Panasonic Home Theater (SC-BTT)
02-04 22:08:13  :   Panasonic S60
02-04 22:08:13  :   Panasonic VT60
02-04 22:08:13  :   Sony Blu-ray (2013)
02-04 22:08:13  :   Xperia Z3
02-04 22:08:13  :   Chromecast
02-04 22:08:13  :   Hisense K680
02-04 22:08:13  :   LG UB820V
02-04 22:08:13  :   LG WebOS TV
02-04 22:08:13  :   Panasonic TV
02-04 22:08:13  :   Samsung BD-C6800
02-04 22:08:13  :   Samsung D7000
02-04 22:08:13  :   Samsung EH6070
02-04 22:08:13  :   Samsung ES8000
02-04 22:08:13  :   Samsung ES8005
02-04 22:08:13  :   Samsung F5100
02-04 22:08:13  :   Samsung F5505
02-04 22:08:13  :   Samsung F5900
02-04 22:08:13  :   Samsung H4500
02-04 22:08:13  :   Samsung H6400
02-04 22:08:13  :   Samsung H6500
02-04 22:08:13  :   Samsung HT-E3 Series
02-04 22:08:13  :   Samsung HU7000
02-04 22:08:13  :   Samsung HU9000
02-04 22:08:13  :   Samsung LED TV
02-04 22:08:13  :   Xbox One
02-04 22:08:13  :   AirPlayer
02-04 22:08:13  :   Android
02-04 22:08:13  :   Azur BD
02-04 22:08:13  :   D-Link DSM-510
02-04 22:08:13  :   DirecTV
02-04 22:08:13  :   Freebox
02-04 22:08:13  :   Freecom MusicPal
02-04 22:08:13  :   Hama IR320
02-04 22:08:13  :   iPad / iPhone
02-04 22:08:13  :   KalemSoft Media Player
02-04 22:08:13  :   LG LA6200
02-04 22:08:13  :   LG LA644V
02-04 22:08:13  :   LG LM620
02-04 22:08:13  :   LG LM660
02-04 22:08:13  :   LG LS5700
02-04 22:08:13  :   LG Smart TV Upgrader
02-04 22:08:13  :   Logitech Squeezebox
02-04 22:08:13  :   Netgear NeoTV
02-04 22:08:13  :   Netgem N7700
02-04 22:08:13  :   Nokia N900
02-04 22:08:13  :   Onkyo TX-NR717
02-04 22:08:13  :   OPPO BDP
02-04 22:08:13  :   OPPO BDP-83
02-04 22:08:13  :   Panasonic TX-L32V10E
02-04 22:08:13  :   Panasonic U30Z
02-04 22:08:13  :   Philips Aurea
02-04 22:08:13  :   Philips TV
02-04 22:08:13  :   Pioneer Kuro
02-04 22:08:13  :   PlayStation 3
02-04 22:08:13  :   PlayStation Vita
02-04 22:08:13  :   Popcorn Hour
02-04 22:08:13  :   Realtek
02-04 22:08:13  :   Roku 3 (NSP 3)
02-04 22:08:13  :   Roku 3 (NSP 5)
02-04 22:08:13  :   Samsung AllShare
02-04 22:08:13  :   Samsung AllShare C/D
02-04 22:08:13  :   Samsung C6600
02-04 22:08:13  :   Samsung Galaxy S5
02-04 22:08:13  :   Samsung Mobile
02-04 22:08:13  :   Samsung SMT-G7400
02-04 22:08:13  :   Samsung WiseLink
02-04 22:08:13  :   Sharp Aquos
02-04 22:08:13  :   Showtime 3
02-04 22:08:13  :   Showtime 4
02-04 22:08:13  :   Sony Bravia 4500
02-04 22:08:13  :   Sony Bravia 5500
02-04 22:08:13  :   Sony Bravia BX305
02-04 22:08:13  :   Sony Bravia EX
02-04 22:08:13  :   Sony Bravia EX620
02-04 22:08:13  :   Sony Bravia HX
02-04 22:08:13  :   Sony Bravia HX75
02-04 22:08:13  :   Sony Bravia NX70x
02-04 22:08:13  :   Sony Bravia W
02-04 22:08:13  :   Sony Bravia XBR
02-04 22:08:13  :   Sony Home Theatre System
02-04 22:08:13  :   Sony SMP-N100
02-04 22:08:13  :   Sony STR-DA5800ES
02-04 22:08:13  :   Sony Xperia Z/ZL/ZQ/Z1/Z2
02-04 22:08:13  :   Streamium
02-04 22:08:13  :   Technisat S1+
02-04 22:08:13  :   Telefunken TV
02-04 22:08:13  :   Telstra T-Box
02-04 22:08:13  :   Thomson U3 Series
02-04 22:08:13  :   Unknown renderer
02-04 22:08:13  :   VideoWeb TV
02-04 22:08:13  :   Vizio Smart TV
02-04 22:08:13  :   WD TV Live
02-04 22:08:13  :   WMP
02-04 22:08:13  :   XBMC
02-04 22:08:13  :   Xbox 360
02-04 22:08:13  :   Yamaha R-N500
02-04 22:08:13  :   Yamaha RX-A1010
02-04 22:08:13  :   Yamaha RX-V3900
02-04 22:08:13  :   Yamaha RX-V671
02-04 22:08:13  Checking the fontconfig cache in the background, this can take two minutes or so.
02-04 22:08:14  Searching for plugins in /Applications/Universal Media Server.app/Contents/Resources/plugins
02-04 22:08:14  Found plugin: net.pms.external.Gs_plugin
02-04 22:08:14  Found plugin: net.pms.movieinfo.MovieInfo
02-04 22:08:14  Registering transcoding engine: FFmpeg Audio
02-04 22:08:14  Registering transcoding engine: MEncoder
02-04 22:08:14  Registering transcoding engine: VLC
02-04 22:08:14  Registering transcoding engine: FFmpeg Web Video
02-04 22:08:14  Registering transcoding engine: MEncoder Web
02-04 22:08:14  Registering transcoding engine: VLC Web Video
02-04 22:08:14  Registering transcoding engine: tsMuxeR
02-04 22:08:14  Registering transcoding engine: Audio High Fidelity
02-04 22:08:14  Registering transcoding engine: VLC Web Audio (Legacy)
02-04 22:08:14  Registering transcoding engine: VLC Web Video (Legacy)
02-04 22:08:14  Registering transcoding engine: dcraw Thumbnailer
02-04 22:08:15  Gs 0.65 using path /var/folders/62/t6s1mj1x6mjf3b79zjk2d4gw0000gn/T/universalmediaserver/gs_plugin tiny mode false init delay 3000 zero_fill false
02-04 22:08:15  Using address /10.0.1.3 found on network interface: name:en0 (en0)
02-04 22:08:15  Created socket: /10.0.1.3:5001
02-04 22:08:16  Using the following UUID configured in UMS.conf: cad56be9-81aa-489c-8cbd-e5f56a0d53a8
02-04 22:08:16  No IP filter specified, access granted to /10.0.1.5
02-04 22:08:16  No IP filter specified, access granted to /10.0.1.2
02-04 22:08:16  Media renderer was not recognized. Possible identifying HTTP headers: User-Agent: MacOSX/10.9.5 UPnP/1.0 Cling/2.0
02-04 22:08:16  The server is now available for renderers to find
02-04 22:08:17  Checking shared folder: /Users/cosmo/Documents
02-04 22:08:20  The file /Users/cosmo/Documents/38 попугаев/01. 38 попугаев.avi could not be parsed. It will be hidden
02-04 22:08:20  The file /Users/cosmo/Documents/38 попугаев/02. Куда идет слоненок.avi could not be parsed. It will be hidden
02-04 22:08:20  The file /Users/cosmo/Documents/38 попугаев/03. Как лечить удава.avi could not be parsed. It will be hidden
02-04 22:08:20  The file /Users/cosmo/Documents/38 попугаев/04. Бабушка удава.avi could not be parsed. It will be hidden
02-04 22:08:20  The file /Users/cosmo/Documents/38 попугаев/05. А вдруг получится.avi could not be parsed. It will be hidden
02-04 22:08:20  The file /Users/cosmo/Documents/38 попугаев/06. Великое закрытие.avi could not be parsed. It will be hidden
02-04 22:08:20  The file /Users/cosmo/Documents/38 попугаев/07. привет мартышке.avi could not be parsed. It will be hidden
02-04 22:08:20  The file /Users/cosmo/Documents/38 попугаев/08. Ненаглядное пособие.avi could not be parsed. It will be hidden
02-04 22:08:20  The file /Users/cosmo/Documents/38 попугаев/09. Зарядка для хваоста.avi could not be parsed. It will be hidden
02-04 22:08:20  The file /Users/cosmo/Documents/38 попугаев/10. Завтра будет завтра.avi could not be parsed. It will be hidden
debug.log
(39.77 KiB) Downloaded 864 times
