Playback issues on PS3
Rayman
Post by Rayman »
Hello there,
I am new to the video streaming in general as well as UMS.
My problem is that some videos cannot be played correctly on my PS3. In other cases there are no problems at all, even with 1080p videos.
  • In my first test the was no playback, neither audio nor video. Please see the attached archive test1_ums_dbg.zip.
  • As second test there was audio playback but the video playback was heavily distorted. I don't know what the correct term is :? Please see test2_ums_dbg.zip for that case.
I assume that the problem might be caused by a wrong configured codec?
Finally some general information:
  • Network: Develo dLAN 650+
  • Windows 7 x64
  • UMS 3.5.0
  • K-Lite_Codec_Pack_1040_Full >> hardware acceleration for nvidia graphics card chosen
  • Codec configuration is attached as log >>
  • klcp_codec_log.txt
  • VLC installed
  • Speaker setup 2.0
    test video 1
  • Code: Select all
    Video
    Format                                   : AVC
    Format/Info                              : Advanced Video Codec
    Format profile                           : [email protected]
    Format settings, CABAC                   : Yes
    Format settings, ReFrames                : 5 frames
    Codec ID                                 : V_MPEG4/ISO/AVC
    Duration                                 : 2h 14mn
    Bit rate                                 : 4 018 Kbps
    Width                                    : 1 920 pixels
    Height                                   : 794 pixels
    Display aspect ratio                     : 2.40:1
    Frame rate mode                          : Constant
    Frame rate                               : 24.000 fps
    Color space                              : YUV
    Chroma subsampling                       : 4:2:0
    Bit depth                                : 8 bits
    Scan type                                : Progressive
    Bits/(Pixel*Frame)                       : 0.110
    Stream size                              : 3.77 GiB (86%)
    Language                                 : German
    Default                                  : Yes
    Forced                                   : Yes
    Color primaries                          : BT.709
    Transfer characteristics                 : BT.709
    Matrix coefficients                      : BT.709
    Audio #1
    Format                                   : AC-3
    Format/Info                              : Audio Coding 3
    Mode extension                           : CM (complete main)
    Format settings, Endianness              : Big
    Codec ID                                 : A_AC3
    Duration                                 : 2h 14mn
    Bit rate mode                            : Constant
    Bit rate                                 : 192 Kbps
    Channel(s)                               : 2 channels
    Channel positions                        : Front: L R
    Sampling rate                            : 48.0 KHz
    Bit depth                                : 16 bits
    Compression mode                         : Lossy
    Delay relative to video                  : 6s 460ms
    Stream size                              : 184 MiB (4%)
    Language                                 : German
    Default                                  : Yes
    Forced                                   : Yes
    test video 2
  • Code: Select all
    Video
    Format                                   : AVC
    Format settings, ReFrames                : 2 frames
    Duration                                 : 2h 18mn
    Bit rate mode                            : Variable
    Height                                   : 1 080 pixels
    Display aspect ratio                     : 16:9
    Frame rate                               : 23.976 fps
    Color space                              : YUV
    Bit depth                                : 8 bits
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
    Audio #1
    Format                                   : AC-3
    Codec ID                                 : A_AC3
    Duration                                 : 2h 18mn
    Bit rate                                 : 224 Kbps
    Bit depth                                : 16 bits
    Stream size                              : 221 MiB (1%)
    Title                                    : MIC
    Language                                 : German
    Default                                  : Yes
    Forced                                   : Yes
    Audio #2
    Format                                   : DTS
    Format/Info                              : Digital Theater Systems
    Format profile                           : MA / Core
    Mode                                     : 16
    Codec ID                                 : A_DTS
    Duration                                 : 2h 18mn
    Bit rate                                 : Unknown / 1 509 Kbps
    Channel(s)                               : 6 channels
    Channel positions                        : Front: L C R, Side: L R, LFE
    Bit depth                                : 24 bits
    Compression mode                         : Lossless / Lossy
    Language                                 : English
    Default                                  : No
    Forced                                   : No
Do you have any idea what causes these problems?
Any help is very much appreciated. Thanks in advance!
klcp_codec_log.txt
K-Lite Codec Pack - Tweak Tool Information
(13.54 KiB) Downloaded 617 times
test2_ums_dbg.zip
2nd test video - distorted video playback (audio was okay)
(37.79 KiB) Downloaded 635 times
test1_ums_dbg.zip
First test video - no playback at all (neither video nor audio)
(38.19 KiB) Downloaded 595 times
Rayman
Re: Playback issues on PS3
Post by Rayman »
Anyone?
Wolfgan
Post by Wolfgan »
Are the PS3 and UMS server connected via ethernet cable or wifi?
Rayman
Post by Rayman »
Hello Wolfgan,
UMS server and PS3 are connected via ethernet cable via the develo dLAN 650+. In between there is a Gigabit-LAN router.
Most other movies and series I can watch without any problems. That's why I thought it might be misconfiguration codec.
Wolfgan
Post by Wolfgan »
Check the CPU usage on your server when the stuttering happens, maybe the transcoding process is chocking your machine (logs indicate transcoding happening, just search the logs for tsmuxer and mencoder entries)
Thanks for the detailed report. By default, UMS doesn't use codecs.
The reason for the second file having distortions may be due to it being a remux - its bitrate may be too high for the PS3 to support over network instead of disc. Just a guess.
When you have a file that doesn't work you can always go into the #TRANSCODE# folder and select a different engine for that file, usually if MEncoder fails then FFmpeg will succeed and vice versa.
Rayman
Post by Rayman »
Thank you for the information :) I will have a look at it and get back to you later.
Rayman
Post by Rayman »
SubJunk wrote:Thanks for the detailed report. By default, UMS doesn't use codecs.
Selecting a different engine did the trick :)
The topic can be solved/closed I think. Thank you!
