Swedish characters
Swedish characters
In my Linux installation (Debian Squeeze) there is a problem, but I have managed to have UMS start when the computer start.
All folders and files set to be viewable in network are not there.
If I have characters in swedish charset in names like åäöÅÄÖ the file/folder i hidden.
Is there a way to resolve that?
In windows installation it works with swedish charset, but Linux is much better...
- SharkHunter
- Developer
Re: Swedish characters
As some might know I'm swedish and the only issue I've had with the åäö stuff is that they look weired (it should not be hidden).
Pls upload logs.
Pls upload logs.
I have found a log (debug.log) but I can't upload (Debian.zip). I just get a new login and the message is gone.
No file?
How to upload?
Every folder and file with Swedish characters are no visibly.
No file?
How to upload?
- SharkHunter
- Developer
Uploading file to here should be easy as 1-2-3.
Just click upload attachment and all should work from there
This has happened to me in the past too, and I don't recall if SubJunk fixed it in phpbb or it went away by itself somehow. Maybe try a different browser, or upload to an external fileserver.johmor wrote:I just get a new login and the message is gone.
Still can't upload, even with IE.
Upload attachment, choose file, add the file. Then I have to logon again - post is gone!
Can I mail the zip-archive...?
- SharkHunter
- Developer
You can upload to some fileshare (like pastebin or like) and paste the link here
Here is part of my debug.log: http://pastebin.com/bWknZG4P
I hope you can see how to have all folders/files viewable with any character.
- SharkHunter
- Developer
I see a lot of
in your log. UMS doen't find mplayer which it needs (maybe to get some thumb or so). Make sure you got an mplayer and that UMS can find it. I don't know if this is that case but a crash could lead to funny things.
DEBUG 2014-04-17 18:12:18.250 [pool-45765-thread-3] Starting mplayer -identify -endpos 0 -v -ao null -vc null -vo null -dvd-device /home/mythtv/MEDIA/Video/VIDEO_TS dvd://1
ERROR 2014-04-17 18:12:18.254 [pool-45765-thread-3] Error initializing process:
java.io.IOException: Cannot run program "mplayer": error=2, No such file or directory
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1041) ~[na:1.7.0_51]
at net.pms.io.ProcessWrapperImpl.run(ProcessWrapperImpl.java:179) [ums.jar:3.5.0]
at net.pms.io.ProcessWrapperImpl.runInSameThread(ProcessWrapperImpl.java:300) [ums.jar:3.5.0]
at net.pms.dlna.DVDISOFile.resolveOnce(DVDISOFile.java:113) [ums.jar:3.5.0]
at net.pms.dlna.DLNAResource.resolve(DLNAResource.java:1166) [ums.jar:3.5.0]
at net.pms.dlna.DLNAResource.run(DLNAResource.java:1010) [ums.jar:3.5.0]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) [na:1.7.0_51]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) [na:1.7.0_51]
at java.lang.Thread.run(Thread.java:744) [na:1.7.0_51]
Caused by: java.io.IOException: error=2, No such file or directory
at java.lang.UNIXProcess.forkAndExec(Native Method) ~[na:1.7.0_51]
at java.lang.UNIXProcess.<init>(UNIXProcess.java:135) ~[na:1.7.0_51]
at java.lang.ProcessImpl.start(ProcessImpl.java:130) ~[na:1.7.0_51]
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1022) ~[na:1.7.0_51]
... 8 common frames omitted
Thank You!
So easy to have things going. The computer is running without a screen, just as a server för Mythtv, Logitec and UMS.
I didn't have to have mplayer in the box. UMS worked, but not with Swedish chars in folder/files.
Just to install mplayer and restart. All working!
Some problem to autostart UMS. Think it's start too early so network isn't up....
